Powerstroke Boost Number??
Old Jan 5, 2007 | 07:36 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I have always been told anything much over 30 to 35 is pushing the limits, is this accurate? The reason I ask is that I installed a juice with attitude package last weekend on an 05 Cummins and on level 3 it hit 40 pounds of boost no problem. I have never seen much more than 20 with mine. What do you guys think? Think the Dudge is gonna blow up?
Old Jan 5, 2007 | 07:45 PM
bigtorque's Avatar
bigtorque
probably not if mr cummins has done exhaust and intake too. those cummins can take lots of abuse, but the truck it sits in cant take any.
Old Jan 5, 2007 | 07:49 PM
Uzumati's Avatar
Uzumati
Stock you will be lucky to see much over 20. The PCM defuels at 24psi, much over that anyway and all you are pushing is hot air the turbo gets very ineficient
Old Jan 5, 2007 | 07:57 PM
Lushman's Avatar
Lushman
I rarely saw 20 in stock, but with the DP chip easily saw 30 on a few occations at WOT and actually threw a few codes and turned on the SES light! The stock HPOP can't keep up at that point. I don't know anything about the cummins though.
What mods have you done to yours, or is it stock?
Old Jan 5, 2007 | 07:59 PM
crack's Avatar
crack
with my dp I can only see 21max....I dont think ive found my boost leak yet
Old Jan 5, 2007 | 08:03 PM
Lushman's Avatar
Lushman
I can get to 30 in the 80 econo setting if I really get on it and stay there till about 80.
Old Jan 5, 2007 | 08:07 PM
THE KING's Avatar
THE KING
Happy to say with my newly intalled guages, lol. My truck has a Air box and thats it and it makes 16 to the floor.
Old Jan 5, 2007 | 08:08 PM
bigtorque's Avatar
bigtorque
ive seen 26 tops.
hey CRACK, did you adjust your waste gate after your ATS housing was intalled, also, where is you boost being read from. just trying to help
Old Jan 5, 2007 | 08:11 PM
Powerstrokedlariat
4'' exhaust, 80hp Predator (yuck), Dp on the way, 6637 filter, WW, valve body in tranny, zoo-dad mod, absolutely no boost leaks to speak of. Gauges, of course. Probably forgetting some stuff but you get the idea.
I was just so shocked to see 40 psi in the cummins. It has 5 '' exhaust and a bully dog intake, that's it. Turbo sure screams loud in that thing.
Old Jan 5, 2007 | 08:14 PM
bigtorque's Avatar
bigtorque
? where are you reading your boost at. MAP/WASTEGATE/AIRHORN
Old Jan 5, 2007 | 08:15 PM
Powerstrokedlariat
map on mine, his plugged into a wiring harness.
Old Jan 5, 2007 | 08:21 PM
bigtorque's Avatar
bigtorque
humm, not to sure about the electronic map boost reading, it may only let you see 20, if it were machanical, like a boost T, you could see a little more than 20.
i saw 21 stock with a MAP T.
Powerstrokedlariat
Thanks, something to look into doing soon.
Old Jan 5, 2007 | 08:24 PM
bigtorque's Avatar
bigtorque
if you do the AIH delete with boost fitting, it well read the most boost straight from the air horn for about 29 bucks. just a thought.
Old Jan 5, 2007 | 08:27 PM
zontral's Avatar
zontral
when my truck was stock I only saw about 18 to 20 psi when I was climbing hills with my trailer and doing about 70-75 mph with the wastegate disconnected.
