Need some opinions
Old Jan 5, 2007 | 02:19 PM
Ford_dad's Avatar
Ford_dad
Question Need some opinions
Hi, i need a few honest opinions. I have a 99 F250 2wd, adn it sets nose low. Now the question, should i put a lift on it to get a little taller and level the ride or drop the back down and go that way??? I am not sure if i would like a 2wd that is lifted even a little??? Any advise would help...
Thanks Joe
Old Jan 5, 2007 | 04:33 PM
ron's power stroke's Avatar
ron's power stroke
its your ride!!!!!! make it your way...no body else matters..after all its still a FORD
Old Jan 5, 2007 | 04:34 PM
Pocket's Avatar
Pocket
It's up to your personal tastes. Any time you lift up the front a bit, you lose fuel mileage. On the other hand, dropping the rear down will cause you to lose a bit of towing capacity. Depending on how heavy you tow, this may or may not affect you. For most loads, this won't be a factor. But if you are towing a loaded down 5th wheel, then you're looking at some major sagging.
Old Jan 5, 2007 | 04:51 PM
Ford_dad's Avatar
Ford_dad
Yea i don't carry very heave loads, mostly four wheelers and bikes less than 3500 lbs total... Yea like you said it is a ford... yea the fuel thing is always a concern anymore... Just want to level it out a bit i guess... Thanks for the help guys.
Joe
Old Jan 5, 2007 | 05:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I would guess you need new front coil springs. You may notice that the front tires lean inwards to each other? (Negative camber)
