Sponsored by: Auxito
Recommended tire pressure
Old Jan 5, 2007 | 02:10 PM
hrsetrdr's Avatar
hrsetrdr
My '99 f-150 ext cab has LT245/75R16's... wondering what a good tire pressure would be. The information on the sidewall shows a pretty wide range of psi's, related to load. This truck mostly runs "unladen".
Thanks
Old Jan 5, 2007 | 02:32 PM
xtrford's Avatar
xtrford
I usaully back off between 2-4 psi from the maximum, especially during the hotter months. Your mpgs won't suffer much and it makes the ride a little less rough.
Old Jan 5, 2007 | 04:03 PM
LxMan1's Avatar
LxMan1
Go by the door sticker, it will drive best this way. Mine is a 4x4 and recommends 35psi all around.
Old Jan 10, 2007 | 11:37 AM
charlesh's Avatar
charlesh
My 03 4X4 4.6 also recommends 35 psi.
Be aware that a good rule of thumb is that for every 10 degrees drop in temperature the tire pressure will drop 3 psi. Soooo, if you check your readings on a 50 degree day and then the temperature drops to 30 degrees you will now have around 29 or 30 psi in your tires.
Old Jan 10, 2007 | 12:22 PM
beekermartin's Avatar
beekermartin
I believe it's 1 psi for every 10 degrees. 3 sounds a bit extreme. Sometimes its 40 degrees in the morning and 80 in the afternoon. A 12 psi drop in pressure would be noticeable. 4 on the hand may not be.
BTW, the fluctation using air is the reason why nitrogen is becoming more popular for tires. It doesn't fluctuate nearly as much, if at all, and it has no moisture.
Old Jan 10, 2007 | 12:26 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Im running 285-75-16's and run 35psi all around. If I were you, I would put in what the door sticker recommends and adjust from there.
Old Jan 10, 2007 | 12:43 PM
hrsetrdr's Avatar
hrsetrdr
It completely escaped me that there IS a sticker with basic info on the door frame!
Front @32 psi <cold> / Rear @35 psi <cold>
Exactly what I was looking for! </cold></cold>
Old Jan 10, 2007 | 12:58 PM
preppypyro's Avatar
preppypyro
I run 35 psi on mine all year around, works well.
Old Jan 10, 2007 | 11:25 PM
Octane's Avatar
Octane
Go with what it says on the inside of the doorjamb. On my '99 it says 35 psi. I personally go with 38 psi front, 32 psi rear. The way I look at it, the front tires have more weight on them because they support the weight of the engine, so they need more psi than the rears. My tire wear is pretty even, so Id say its a pretty good pressure to run the tires at.
rcosta
Aug 8, 2012 09:31 PM
john fin
Jun 24, 2009 02:27 PM
RBrendel
Jun 7, 2002 05:26 PM
OfficerLow
Apr 9, 2002 08:23 PM
seebeew
Jul 26, 2001 06:51 PM
