1978 - 1996 Big Bronco
Horn Relay
Old Jan 5, 2007 | 11:07 AM
brownbronco's Avatar
brownbronco
Horn Relay
My horn doesn't work. I'm trying to start troubleshooting it, and found the wiring diagram. Does anyone know where the horn relay and horn are physically located?
1980 Bronco XLT
351M
Old Jan 5, 2007 | 10:42 PM
Aciancio's Avatar
Aciancio
On a 1980 there is not a relay the horn gets its power from blk-org fusible link from the solenoid (also powers the running and head lights) then the power goes thru the headlight switch (yel-lt blu wire @pin1) to the steering column connector (pin11) to the horn switch, then from the horn switch back to the steering column connector (pin8 (i think) yel-lt grn) to the horns. There are two horns (hi & low) they are mounted onto the radiator bracket on the driver side. I hope this helps let me know if you have any more questions
Amphihauler
Feb 1, 2017 12:43 PM
PhilcoPGM
Dec 7, 2010 07:44 PM
sleddog60
May 18, 2009 09:29 PM
93aero257k
Aerostar
Apr 18, 2005 09:30 AM
country boy
Nov 8, 2002 04:30 PM
