This really is an impressive GPR!
  #76
Old 10-10-2007, 05:19 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Ok, got it now. Maybe the GPRs your buying are really starter relays disguised as a GPR. They look the same. I know the cheapies from Autozone & Napa will not hold up very long. Even the one the dealer sells, big $$, won't last as long as the Stancor.
That's a lot of GPR's in a short period. Do you do a lot of short trips. The GP's may be cycling too long everytime you start it even with engine warmed up or worse yet, they may be sticking on for some reason.
I can tell when the GPR is cycling by watching the voltmeter. I ususally keep an eye on them.
  #77
Old 10-10-2007, 06:44 PM
DND58's Avatar
DND58
DND58 is offline
I try to stay away from short trips, and engine is up to operating temperature. I will install spare from IH. My quarter says it fires right up. I have not checked when temps are up. Glow plugs should not be called for then, correct? If they are, this excessive usage could be the problem? Engine oil temp triggers the pcm to provide ground for circuit? Kwiks push button and the LED indicator are sounding promising. Thanks
DND58
  #78
Old 03-20-2008, 10:39 AM
F250_'s Avatar
F250_
F250_ is offline
Updated pricing information on the monster Tyco relays. $89
http://www.evsource.com/tls_relays.php
The Stancor / White Rogers unit is still priced at $50 at the link below.
http://www.alliedelec.com/search/Pro...E1A9003F4CE17F
  #79
Old 03-20-2008, 10:43 AM
empiretc's Avatar
empiretc
empiretc is offline
Thanks Pete!! $200 was too high, so I just forgot about getting one. those are the only prices i have seen come down in a while.
  #80
Old 03-20-2008, 10:53 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I just helped a buddy out with this a month or two ago. It was actually a bit comical...
He said his truck has been hard to start when it was cold for the last couple winters. I asked him if there was any smoke and he said "Yeah, white. Why??".
I printed out Guzzle's write up on this and he's up and running...
  #81
Old 02-19-2010, 11:08 AM
AltaPowder's Avatar
AltaPowder
AltaPowder is offline
Has anybody put a STANCOR into a E350 van ?
Looks as though I have some issues/concerns (perhaps limitations) with wiring placement, physical mounting in relationship to my transmission dipstick tube
and the right rear corner of the van . . .
My intent is to install one of these.
Davdi
  #82
Old 02-19-2010, 11:24 AM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
Just installed my Stancor a couple weeks ago. it definitely starts a lot easier.havent plugged in since i installed it, but was having to do that with the OLD GPR, picked it up for $44 online shipped to my door.
  #83
Old 02-19-2010, 11:32 AM
canister's Avatar
canister
canister is offline
What site did you get it from?
  #84
Old 02-19-2010, 11:42 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Are the bigger Stancor GPR's overkill for us folks living in the South were the temps are not as low?I have been thinking about getting one to have on hand but did not know if I really needed it.
  #85
Old 02-19-2010, 11:50 AM
PwerStroke99
Onlinecomponents.com. Then just type in the part#
  #86
Old 02-19-2010, 01:47 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
Hello Friends, I noticed in the 'write up' on the first page that it said to disconnect both batteries. My owners booklet said that if power is lost to the radio (someone trying to steal it) that it will not work and must have a dealers code put in it to work. What is the scoop on this? Is the radio and all electrical elements 'OK' if both batteries are disconnected?
Brother Les
  #87
Old 02-19-2010, 01:50 PM
canister's Avatar
canister
canister is offline
How much was shipping? It doesn't give a shipping price, it says that it will be added to the invoice. Just don't want to get charged $15 shipping.
  #88
Old 02-19-2010, 02:35 PM
PwerStroke99
i got free shipping. it was $44 to my door
  #89
Old 02-19-2010, 02:50 PM
canister's Avatar
canister
canister is offline
I'm getting $45.12 and shipping will be added to my invoice.
  #90
Old 02-19-2010, 10:50 PM
jcrammell's Avatar
jcrammell
jcrammell is offline
Hey Barry it may be a little overkill for us down here in the south, however I bought one and will be replacing the original soon just so that I know that I will have a reliable GPR. Plus I think it is a little PMS also.
Quick Reply: This really is an impressive GPR!
