Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Air bag problem
Old Jan 5, 2007 | 07:06 AM
CrazyMax's Avatar
CrazyMax
Air bag problem
Hi everyone,
I have a prob with the air bags. The air bag light in the dash flashes 3-4 times and stops, then starts again, stops and starts flashing again then it stays on. The light always flashes few times at the beginning before staying on. Anybody had this problem before ? anybody has a solution ?
Thanks for your help
<o></o>
Old Jan 5, 2007 | 08:03 AM
tonyford's Avatar
tonyford
Hey CrazyMax, if someone on here cannot help you real soon, I would not hesitate to get this checked and/or fixed as soon as possible. There is too much riding on not having your airbags working properly.
Old Jan 5, 2007 | 08:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome CrazyMax,to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Jan 5, 2007 | 10:03 AM
CrazyMax's Avatar
CrazyMax
I solve the problem !! I was surfing on the forum and found https://www.ford-trucks.com/forums/4...bag-light.html
And someone had the same probleme as mine. But finally it was the connector under the drivers seat. Thankx to all !
Old Jan 5, 2007 | 10:06 AM
CrazyMax's Avatar
CrazyMax
Unhappy
Sorry but i'm from Montreal Quebec and you have no chapter in QC
Old Jan 5, 2007 | 08:05 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Yeah the connectors under the seats are junk on these... you can try unplugging them, use a small screwdriver to tighten up the pins a bit and reconnect. If this doesn't work you can buy new connectors from FORD, but they have to be soldered in... or if you're brave you can snip the connectors out completely and solder the wires together, although I'm not sure of the legality of doing that.
The Air Bag monitor is VERY touchy about resistance in that circuit, so whatever you do must be done right.
Good luck. (Keep in mind this is assuming the connectors ARE your problem... although it's quite possible there are many other things that can set an air bag light.)
Old Jan 6, 2007 | 05:14 AM
IB Tim's Avatar
IB Tim
We do have the Canadian National Chapter
Old Jan 6, 2007 | 02:57 PM
MMRacing's Avatar
MMRacing
2003 Escape Air Bag Problem
I followed the advice of unplugging the passenger side connector under the seat and reconnecting it. It solved my problem. Thanks Tim
bismic
Mar 9, 2022 09:20 AM
LGS
Sep 24, 2016 08:08 AM
gastelumri
Sep 24, 2015 05:37 PM
bismic
Aug 10, 2015 10:35 AM
evan96F250
25
Jul 21, 2010 04:42 PM
