Engine Pull and Replacement
I just purchased a 1996 F250 XL from my boss for $500 so I am very excited. Only problem is the engine is blown. I also just purchased a 4.9l 300c.i. I6 engine with 94k miles on ebay for $150. Here is the previous owner’s description of the engine:<O
<O
THIS ENGINE WAS TAKEN FROM A 91 F150 LARIAT THAT HAD A BAD FRAME. THE ENGINE IS VERY CLEAN<O
></O
><O
STRONG RUNNING WITH PLENTY OF TORQUE. THE OIL PUMP WAS REPLACED AS WELL AS HOSES, PLUGS AND WIRES. THE ODOMETER ON THE TRUCK WAS 94K.<O
<O
A visual inspection of the engine also indicates that there are no issues but who knows until I get it in there. For some reason I trust the guy and I hope I'm right. Anyway if it’s no good I am only out $150 and my time.<O
<O
My question is; should I do any preventative maintenance to the engine before I swap it in. I.E. Oil seals, oil pan gasket, etc… Obviously now would be the easiest time.
<O
Also, does anyone see any issues swapping a 1991 F150 I6 into a 1996 F250.<O
<O
Finally, if anyone has any tips to help with the process of swapping these engines that would be great.<O
<O
Any and all suggestions will be greatly appreciated. I am clearly new to the Ford truck scene but am very excited to get started.<O
</O
<O
Thanks again!<O
</O
Evan<O
</O
<O
The current and original motor in the truck is a inline6 4.9l. I believe they put a couple of these motors in the F250 XL's but I am no mid 90's Ford truck aficionado either.
<O
</O
I suppose it is possible that someone swapped the badges a long time ago but I doubt it.
<O
Thanks again for the suggestions and it is pretty much what I figured. I do wonder if anyone else thinks it would be a good idea to change the head gasket. It seems to me that it would be a lot of work for something that may in fact be fine.<O
<O
I suppose this post would be better suited to the inline 6 specific forum but any and all help is appreciated.<O
if you aren't leaking or burning anything i wouldn't touch it... Then again with engine alread plucked and out you might want to change it and the valve cover gasket with a good felpro that way you don't have any surprise leaks after install.
If you believe him then you can leave the bottom end alone... but if you feel ambitious I would pop off the oil pan and check to make sure the oil pump and oil pan gasket were replaced... Trust me on this on you'd be way better off replacing them now!!! The seal and pump can be done later but it's a huge pain in the **** unless you want to lift the motor for more room... Plus if you pop the oil pan you can get a good look at the bottom end to make sure everything is in good order.
Also not that you need to butt you may want to consider going to a header instead of the cast iron exhaust manifold... more power and less restriction (but that depends on the condition of your stock/current set up.
Just a few thoughts of preventative and hp upgrades as long as your this far in...
I finally got the motor swapped. A torn mcl slowed me down a little bit but I got it in.
<O
<O
</O
><O
I tried firing it up but the starter just bogs down and barely turns the motor over. The battery gauge is at about 1/3 with the key turned to accessory but when I go to start it falls way down. Also, the battery cables get hot to the touch. They are not smoking, but they are hot. I read that this can be caused by resistance possibly due to corrosion but there is no visible corrosion.
The truck has set for two years.<O
Do I need a new starter? Solenoid? Ignitions switch?<O
<O
I also have a fresh battery.<O
<O
If anyone can help it would be much appreciated. This has been a long project and I am dying to get this thing running
<O
Thanks in advance.<O
ffice
ffice" /><o
></o
><o
></o
>I am not quite certain how to properly seat the torque converter so I guess I missed this step. The motor is bolted to the transmission and the torque converter is definitely in there. I'm not sure what else you can do.<o
></o
><o
></o
>Thanks<o
></o
ffice
ffice" /><o
></o
><o
> </o
>Was this incorrect?<o
></o
><o
> </o
>I can’t see what difference it would make since the torque converter must be fastened to the flywheel in the end anyway but I am here to learn. Seems to me that if the motor is bolted to the bellhousing and the torque converter is bolted to the flywheel than by default the transmission shaft should be seated into the torque converter. Is my logic off?<o
></o
><o
> </o
>Are you fairly certain that this is my problem and not an electrical issue?<o
></o
><o
> </o
>I am sorry for all the questions but I am really trying to gain an understanding of this before I pull the motor again. I really would like to avoid pulling the engine if at all possible.<o
></o
><o
> </o
>Thanks again.<o
></o
