gauges
The Cable has a plastic drive on the end where it engages and plugs into the speedometer head. It is designed to snap to prevent speedometer head wind up, and damage.
Also remove the cable and check to see if it's not damaged. Any broken cable filaments, frays or weirdness replace it.
Make sure you lubricate the cable with speedometer cable lubricant, or in a pinch, white lithium grease, to keep everything working smoothly and to prevent speedometer needle "hop".
As for fixing a broken speedometer head, if that is your problem you have three choices.
Take your old cluster apart and Just replace the speedometer head.
Part Number for Speedometer head without trip:
E1TF-17265
2177/8-1
2292/93
As for Instrument clusters. Any Ford Pickup or Bronco, 1981 to 1986 will have what you need. Stay away from the 1980 year model as they are not compatible.
Part number for instrument cluster WITH Gauges WITHOUT tach.
E1TF-10C956-C
Part Number for Instrument Cluster WITH Gauges and tach.
E1TF-10C956-B
The two instrument clusters mentioned above are interchangeable. So if you want to upgrade to Factory Tach, this is your chance. They just plug and play swap. The truck is already wired for tach if it has factory gauges.
Don't discriminate because of transmission either. Just swap the Automatic tranny, Shift Quadrant selector, for the blank in your old cluster. It's held on with two bolt headed screws.
Part Number for Manual Tranny "Auto Shift Selector Blank"
E0TF-7B100
Hope this helps..
Sometime back maybe a year ago. A guy posted a link about buying white backed stock gauges I think they were offered on ebay. If you need only a speedo the wrecking yard is going to be your best bet. outside of ebay.
