After market Gauges
Old Apr 19, 2010 | 10:15 PM
cabloom300's Avatar
cabloom300
After market Gauges
As soon as i complete my 390 build it will be going in to replace the 360 and none of my gauges work. I just order a tach for it but what is the best route for getting the other gauges? Is there a after market set with oil press, water, etc. that would be easy to swap or can the stock gauges be fixed to work well enough?
Old Apr 19, 2010 | 10:27 PM
OrangeJuice's Avatar
OrangeJuice
If the stock guages can't be fixed then you can get new stock guages from LMC or other aftermarket sets. I'm running stock guages and aftermarket guages for a more precise reading.
OJ
Old Apr 19, 2010 | 10:29 PM
hp246's Avatar
hp246
There are any number of quality manufacturers of aftermarket gauges used primarily in the hot rod industry. Any of them would work well. The biggest issue would be matching the fuel gauge with the sending unit in your tank.
You may be able to find a complete instrument cluster online such as on Ebay. Make sure you get the correct year, though as I understand there are sometime wiring discrepancies between the years.
There is probably someone around who could make repairs, but I think you would find a good used gauge set a lot cheaper.
Old Apr 19, 2010 | 10:41 PM
cabloom300's Avatar
cabloom300
Summit Racing SUM-G2972 - Summit Racing® White Face Mechanical Analog Gauge Kits - Overview - SummitRacing.com
What do you guys think about this? Would i be able to tie these gauges in easily? That would eliminate water, oil press, tach (when it comes), then possibly just try to get my old fuel gauge to work
Old Apr 19, 2010 | 11:34 PM
spudgunman's Avatar
spudgunman
I have the early style cluster all working... make sure its not your 5volt source that is broken but PM if you want a cluster
Old Apr 20, 2010 | 07:54 AM
fmc400's Avatar
fmc400
MSEE
I have a set of Sunpro gauges in my truck; I also had a set in my LTD. They work great. Make sure when you plumb the oil pressure gauge that you use copper tubing and not the nylon tubing that usually comes with these kits.
Old Apr 20, 2010 | 10:38 AM
bmarkline's Avatar
bmarkline
Click on this link for some really nice guages
1973- 79 Ford Pickup Instrument System
Old Apr 20, 2010 | 10:59 AM
ecidemon's Avatar
ecidemon
The electronic gauge cluster above is a bit cheaper on bronco graveyard.
Here
jb10's Avatar
jb10
doh! $610. ouch
2zwudz
Nov 5, 2013 09:33 PM
runinbear
Jan 14, 2008 06:09 PM
shadmurphy
Jul 29, 2007 08:50 AM
AT6AERO
Electrical Systems/Wiring
Mar 20, 2004 08:21 PM
