Supply/return size is all the same. If I remember correctly the sizes are 2 1/4 to 2". If I get to my tool box tonight I will measure the left over hose for sure for you! If I don't get back to you tonight remind me here and I will get it to you tomorrow morning.
it was the harder part of the job. I moved my whole unti down a few inches and extended the float arm by a few inches. It was accurate on the bottom end which is where it counts. It took about 150 mile to come off full then it was pretty accurate from 1/2 tank down. I wish I could be more specific on placeement but I think I forgot to take a picute of the final sender before I put it all together. You can check the webshots link in my sig for my install picutres.
