Sponsored by: Real Truck
Mysterious Dinging noise
Old Jan 3, 2007 | 09:05 PM
The Clatterin Diesel's Avatar
I have a 2001 F350 Powerstroke that I affectionately named "The Clatterin Diesel". At any rate on my way home tonight I pulled into the driveway and put it into reverse and a dinging noise started sounded like I had my door ajar or something but my doors were shut and seatbelt was on. I put it in drive to pull forward and the dinging noise kept dinging about every 5 seconds. I turned the lights off and the dinging kept on until I turned the truck off. I am curious as if anyone has had that problem before and what to do about it. In another question I would like to know how to get my clearance lights to work as they do not work with either my parking lamps on or my head lights and I have looked in the owners manual and can not find a fuse for this operation. Any and all help would be appreciated.
-Clint and The Clatterin Diesel.
Old Jan 3, 2007 | 09:23 PM
OBXTucker's Avatar
OBXTucker
Low Fuel Ding?
Back Up Ding?
Left the Headlights ON Ding? (This is my FINAL guess)
"I'm going to miss you" Ding?
I don't have Clearance Lamps on my 250 6.0, so can't help with that one.
Old Jan 3, 2007 | 09:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE
Turn signal ding?
As for the clearance lights, check your wiring. I don't have them (don't think I can get into my garage if I had 1 inch extra height) but from what I understand the wiring harness connects to the main harness behid the passenger kick panel. I would start there to see if you have voltage. Maybe it got disconnected?
Old Jan 3, 2007 | 09:42 PM
I appreciate all the help so far. As for the ding...I have a full tank of fuel. Rarely do I use my turn signals and i live out in the country so I wouldnt have used it to turn into my driveway. I dont have a backing alarm. It just started dinging out of nowhere. I have a 2 hour drive to work tomorrow and I sure hope it fixes itself before then.
Old Jan 3, 2007 | 09:54 PM
redford's Avatar
redford
It's enough to make you dingy.
Old Jan 3, 2007 | 10:19 PM
ryaneverk2's Avatar
ryaneverk2
Hi Clint,
Does your truck beep five times, then pause for a bit, and then beep five times again, and so on? If so, it's related to the airbag system, and is the truck's way of telling you there's an issue such as a burnt out air bag bulb in the dash. There's more info in post #9 of this thread:
https://www.ford-trucks.com/forums/4...g-problem.html
