Sponsored by: Real Truck
which shocks
Old Dec 23, 2006 | 11:34 AM
FTL40's Avatar
FTL40
which shocks
i ama bit sick of the truck hoping around on bumps, it only has 2000 miles on it. i am trying to decide between bilstein and edelbrock, which do you guys tend to like better?
Frank
Old Dec 23, 2006 | 12:54 PM
cc322's Avatar
cc322
Do a search and you will see that Bilstiens get the majority of the votes on here which I would agree with. I have the dr signature series shocks and like them fine with the kit.
Old Dec 23, 2006 | 06:11 PM
ed.the.builder's Avatar
ed.the.builder
Thumbs up
Check out KYB gas shocks. I replaced the oem with them, have Timbrens front and rear, a Hellwig aftermarket rear sway bar (larger diameter than Ford's) and nearly new Mastercraft Courser A/Ts (285 16") on factory steel wheels and I can navigate the tightest highway exit ramps at 45-50 mph with almost no body roll and absolutely no wheel hop. Bought all 4 KYBs on ebay for $179 + shipping. I thought it was a good deal and the truck rides and handles well for over 6500 lbs. unloaded. (3 RKI tool boxes, Trac Racs and a pile of tools add significantly to the rear end weight)
Old Dec 23, 2006 | 08:51 PM
PHWLEE's Avatar
PHWLEE
One vote here for the Bilsteins. Been on for about 2 months now and no problems whatsoever. My truck is stock, and the ride is great with the new shocks.
Old Dec 24, 2006 | 12:05 AM
skipperw's Avatar
skipperw
EDELBROCK IAS. Definitely improved ride and handling!
Old Dec 24, 2006 | 09:35 AM
FTL40's Avatar
FTL40
i have had both bilsteins and ias on cars and i kind of prefer the ias for there ability to be both soft on small bumps but wtill keep things nice and tight, but i am wondering if they would be ok for a truck as i have seen more people comment on the bilsteins
Frank
Old Jan 1, 2007 | 11:43 PM
Toy3zve's Avatar
Toy3zve
On my last truck (a '98 Dodge Ram 1500 4x4) I replaced the worn out OEM shocks with the Edelbrock IAS shocks and was EXTREMELY dissapointed. Felt like someone forgot to add shock oil to the shocks. The truck actually rode worse than with the worn-out Dodge gas shocks. So I pulled the Edelbrocks and installed the Bilsteins. Now the Dodge rode like I pumped up the tires to 80 psi.
So now with my Super Duty I'm ordering the Rancho 9000X shocks.
Old Jan 2, 2007 | 07:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
I used Rancho 9000s on my last truck and hated them. They were very stiff, ride quality was terrible.
Old Jan 2, 2007 | 07:33 AM
Green_Dually's Avatar
Green_Dually
I have the rancho 9000 and love them.I dont care about the hard ride,i bought a truck.So i want it to ride like one.
Old Jan 2, 2007 | 07:43 AM
redford's Avatar
redford
That truck rode like a truck before the RS9000s. Afterwards it rode like a truck with solid rubber tires.
Old Jan 2, 2007 | 09:57 AM
ABFord's Avatar
ABFord
I have a leveling kit on my 06 F350 and also wanting to upgrade my shocks. I was wondering if anybody has tried the procomp mx-6 shocks and if they are any good. I was also considering the rs9000x aswell. I work in the oil patch and drive on alot of rough gravel roads. I am just sick of the truck bouncing all over the place. The fake ranchos just suck to bad. ANyways thanks for the info.
Old Jan 2, 2007 | 06:46 PM
slowmans's Avatar
slowmans
edelbrocks here , have had them on 3 different vehicles and loved the ride on all of them!
Old Jan 2, 2007 | 07:02 PM
tigerman's Avatar
tigerman
I think and empty truck rides crappy. Put some weight in it. Screw the mpg. Mine is loaded with about 300-400 lbs of tools and new Edelbrock IAS shocks. Rides okay for me.
Old Jan 2, 2007 | 09:39 PM
travis dasher's Avatar
travis dasher
I have MX-6's on my truck. It rides great. I have not had any problems with them. Hope this helps.
Old Jan 2, 2007 | 10:09 PM
mlytle's Avatar
mlytle
it wasn't on an sd, but i made the mistake of replacing 55k mile old oem bilstiens on my suburban with rancho 9000's. if you dialed them up, the compression valving was ok, but the rebound damping was way too soft. really not very impressed. never found a setting that i liked. definitely not going to get them for my sd.
