Heated Intake
Old Jan 8, 2007 | 08:04 PM
Col Flashman's Avatar
Col Flashman
JMS-Racing Engines drilled & tapped mine Offenhouser "C" so that Heated Water from the block/radiator would circulate through it to keep it warm.
Old Jan 8, 2007 | 08:32 PM
BigBlue88's Avatar
BigBlue88
Scottfreeman- Yeah, your Holley is backwards. Should see better low-throttle response when turned around.
Old Jan 9, 2007 | 09:37 AM
scottfreeman's Avatar
scottfreeman
Guess I'll have to scrounge up a much longer cable to reach all the way around the whole mess. I was thinking about pulling the throttle lever from under instead of over, but the rocker cover is in the way Maybe I will have to fabricate me a new cable mount. Guess I goofed, I've had about 4 different setups on this manifold. Some where along the line I got confused about which direction the carb faced.
Old Jan 9, 2007 | 11:00 AM
Harte3's Avatar
Harte3
I used a 48" Lokar cable and a Spectre bracket slightly modified. Some have used the stock throttle cable and modified bracket and pulled from the bottom with 2" of spacer under the carb to clear the valve cover. But I looked at that and thought the "throw" off the bottom was a bit short so I opted to go the other way and pull off the top. Ended up with a close fit against the heater core housing but it works just fine.
Old Jan 9, 2007 | 08:29 PM
scottfreeman
4 footer?
So is that the length I need? I was trying to decide how to measure that somewhat accurately today. Guesstimating that mine is a 2 footer right now. I think that I will spend the money to buy the longer cable, I can use the short one on my '66 Ranchero when I get it up and going again someday.
Now I just have to come up with the design of heating the intake with water. I don't want to use the heated carb spacer, scares me. What if the spacer corrodes through and you injest water before you know it?
Old Jan 10, 2007 | 02:20 AM
Bdox's Avatar
Bdox
Originally Posted by srercrcr
Seems to me the coolant would be very slow to warm. I would think getting quickly heated air from around the exhaust manifold via the large flexible tube to the air cleaner is much more efficient. JMO.
The tube from the manifold shuts off after warm up, so you really need both. The coolant maintains the manifold temp.
Old Jan 10, 2007 | 12:18 PM
Harte3's Avatar
Harte3
The stock cable is about 24" but I questimated a 48" and it worked just fine...even shortened the cable a little (not the cable housing) to get the install just right at the carb. You can build a bracket or modify something like a Spectre bracket (a little grinding) to get it to fit where it mounts to the carb base bolt BUT that is with my carb set up. Your's may be a little different...just takes a little adapting and improvising. I suggest staying with a quality cable like the Lokar that way if you get a little tight as I did against the heater housing it will work just fine without binding.
Old Jan 10, 2007 | 05:25 PM
scottfreeman
I am going to use my existing bracket, that is why I need the longer cable.
Old Jan 11, 2007 | 09:07 AM
1982fordf100's Avatar
1982fordf100
I know you have a different year truck but I was able to reuse my orginal throttle cable and throttle bracket. All I had to do was make one bracket to connect the factory bracket to the offenhauser intake. I made this piece:
https://www.ford-trucks.com/user_gal...122204&width=2
Attached the factory throttle bracket to it:
https://www.ford-trucks.com/user_gal...122205&width=0
And then bolted it to the offenhauser dp intake:
https://www.ford-trucks.com/user_gal...122202&width=0
I see too that you have the same 300 cubic inch decal on your air cleaner that I have on mine. Using all the orginal throttle cable and throttle bracket mad the swap really easy. I haven't had a problem with it. Your truck might of been different since its a 1969 vs my 1982.
Old Jan 15, 2007 | 02:19 PM
scottfreeman
Originally mine had linkage and a bell crank to compensate for the off set carb. It never seemed to work correctly after I put the four bbl on it. So I converted it to cable.
Clif Daniel
Escape & Escape Hybrid
17
Dec 21, 2014 07:18 AM
Daniel92f250
New Member Introductions
Jan 22, 2014 09:46 PM
DanielN
Mar 2, 2007 07:45 PM
ford_man
Jan 29, 2007 10:04 AM
61Unibody400
Jun 16, 2006 04:15 PM
