Cylinder Contribution test
Old Jan 3, 2007 | 11:22 AM
Powerkleen's Avatar
Powerkleen
I have seen this listed on this board and was wondering exactly what it was and what kind of readings to look for. I looked at the auto enginuity site and I have got a new laptop that would be great for it. Is the software worth the 379 for the ford package?
Thanks
Anthony
2000 F350 PSD
Old Jan 3, 2007 | 11:42 AM
tjbeggs's Avatar
tjbeggs
well the package is worth if you normally pay somebody else $75 a shot to scan your truck for codes. after about 5 times of getting your truck scanned you could pay for itself.
Yes the autoenginuity will do cylinder contribution tests. what it is a test the determines which cylinder is not performing up to the rest of them. useful for find which cylinder is missing or poor on performance ie bad injector wiring, bad injector, bend push rods, low compression. It won't tell you what the problem is but it will narrow it down to which cylinder.
Old Jan 3, 2007 | 11:47 AM
Powerkleen's Avatar
Powerkleen
Thanks.....i take it by your response that it will show some data to compare the cylinders against each other. I didnt want it if it just show which cylinder was dead....i wanted data.
Thanks again
Anthony
Old Jan 3, 2007 | 11:55 AM
tjbeggs's Avatar
tjbeggs
it won't show data for dead cylinder. no scanner do that. you can see all engine data but there really isn't any data to be shown for a dead cylinder. It can't measure compression or tell you if it getting fuel. Here what you can do though. say you have a miss. cylinder contribution tells you #5 is down you also have a code for #5 injector. You could safely assume that #5 injector has a wiring issue or a dead injector.
Old Jan 3, 2007 | 12:00 PM
Powerkleen's Avatar
Powerkleen
I miss read what you wrote....Sorry about that.
Old Jan 3, 2007 | 12:07 PM
tjbeggs's Avatar
tjbeggs
from what I read I would say that the AE is better than the snapon scanner my dads shop has but it runs $3k. but the snapon does have diagnostic info with where as the AE doesn't. Also if you are into diagnostic on multiple brand vehicles, ford, gm, dodge, honda.... you have to buy the other manufacture bundles. but This said I have access to the snapon scanner 24/7 but AE is on my list to buy especially since I am in process of mounting my laptop for A/V, Navigation and when I get AE diagnostic and data logging!
Old Jan 3, 2007 | 12:14 PM
Uzumati's Avatar
Uzumati
You can look at "Cylinder Rotaional Change %" in live data that will show you a cylinder that is not contributing as much as the rest but it wont tell you the cause ie. Compression, injector, wiring, ect.
Old Jan 3, 2007 | 12:17 PM
GREGROB's Avatar
GREGROB
The AE Ford bundle DOES have diagnostic info.
I have used both the AE and Snap-on and the AE beats the Snap-on hands down. The interface on the snap on is pretty limited.
Old Jan 3, 2007 | 12:20 PM
tjbeggs's Avatar
tjbeggs
Greg bob I did not know that! Glad to hear somebody that has used both. Our shop has Snapon solus. it good but what I have heard has been confirmed by you. AE is better. Only problem is that we work on every vehicle on the road. We still need a scanner with full vehicle coverage including obd1. Does AE do body control and abs stuff?
Old Jan 3, 2007 | 12:23 PM
GREGROB's Avatar
GREGROB
Yep, it does P, U, B, and C codes. It's CAN compatible as well for the new stuff.
See here http://autoenginuity.com/products.html
http://autoenginuity.com/products-scantoolpc.html
Old Jan 3, 2007 | 12:25 PM
Uzumati's Avatar
Uzumati
Even with all the bundles AE is still just a little over 1/2 the price of the Solus
Old Jan 3, 2007 | 12:43 PM
tjbeggs's Avatar
tjbeggs
I thought it was good stuff before! now I bet my dad buy the whole she bang by the end of the year after the Honda package is availible.
thanks guys
and thanks Alan just got the e-mail! also logged in and it worked thanks!
46fordtruck
Jun 28, 2018 07:02 PM
RubenG
Modular V10 (6.8l)
Jul 15, 2017 10:21 AM
Norma stitz
Oct 16, 2016 10:30 AM
BostonDMD06
6.7L Power Stroke Diesel
Aug 4, 2011 09:19 PM
orng1
Aug 18, 2009 08:37 PM
