how do you guys jack your trucks up to do a lift install?
just as the title says:
how do you guys jack your trucks up high enough to put a lift in. I got a 02 PSD long/crew. I have a 4" lift for it and can't get the truck high enough to put it in lol
yes i know, it's a dumb question, but i need your help!
I used 6 ton jack stands because they are taller, and have had to take the tires off to get the axles to drop far enough. I have also jacked it in stages to keep building higher under it.
Big a$$ jackstands, and platforms (very sturdy) under the stands when they do not reach. Also remove tires to lower axle instead of raising the truck further. Oh yeah make sure you do not lift it in the garage, makes it kinda tough to get it out after the lift is installed. LOL!
