Trailer Brake Controller
Old Sep 19, 2008 | 09:54 PM
white Buffalo's Avatar
white Buffalo
Prodigy is a good controller, but the new P3 is the shiznit (as Mike says!).
Tekonsha P-3 Trailer Brake link to review/video
- No level adjustment necessary - it adjusts itself to varying terrain as you drive.
- Continual diagnostics check for proper connection, shorted magnet condition, bad ground, etc
Excellent writup Stewart!
Old Sep 19, 2008 | 11:23 PM
Stewart_H's Avatar
Stewart_H
Thank you, sir!
Stewart
Old Sep 19, 2008 | 11:47 PM
white Buffalo
Reps sent.....
Old Sep 19, 2008 | 11:52 PM
Stewart_H's Avatar
Stewart_H
Sweet! Thanks!
It's not often a regular Joe like me can help and add to the quality info here in the PSD forum.
Much appreciated!
Stewart
Old Nov 7, 2013 | 03:13 PM
Fraree's Avatar
Fraree
Quote-
Now, in this picture below, the same black flat plug plugs into the back of the contoller, but on the other end is the Ford specific plug that plugs into the gray plug in the picture I posted in the above post.
Having this Ford specific harness means you don't have to splice anything. All you have to do is locate the gray plug and plug your harness into it.
Stewart[/quote]
Thanks for posting this, now I know where the factory adaptor wire goes under the dash.
Old Nov 7, 2013 | 08:27 PM
helifixer's Avatar
helifixer
the last ford I put a brake controller in (2001) the harness/plug for the brake controller was all the way up against the fire wall in the center if the cab! some clown at the factory thought it would be fun to hide it. all others have been where the picture that Stuart posted shows it.
also those wires that look like brake control wires are just pre loomed pass through wires. thay go in to the engine bay and are normally by the brake master cylinder.
Old Nov 7, 2013 | 10:38 PM
Stewart_H's Avatar
Stewart_H
No prob!
Sigh......
Stewart
Old Nov 8, 2013 | 08:21 AM
helifixer's Avatar
helifixer
Originally Posted by Stewart_H
No prob!
Sigh......
Stewart
sorry auto correct got me.
Old Nov 8, 2013 | 12:47 PM
Stewart_H's Avatar
Stewart_H
Every time it happens (and dang if it aint happening a lot recently) I play with the idea of changing the font I use for my name that I put on every post, to a larger size to make it stand out.
Or maybe see if I can make the font for my user name in bold lettering.
Stewart
Old Nov 8, 2013 | 09:47 PM
Fraree's Avatar
Fraree
Red face Obscure wiring
That must be where the wiring is in this too, nowhere to be seen. Might have to send the electronic periscope into the depths for some investigation. This truck is RHD from the factory, so little wonder things are a little confused
Old Nov 30, 2013 | 06:21 PM
Fraree's Avatar
Fraree
Found at last
Found that plug under the dash, clipped up, in the centre, when pulling the dashboard facia out, the whole deal, from left to right while chasing the lovely vacuum fault associated with the default setting on the heater/Ac . Just waiting for the connector to arrive from the USA now to complete the job (must be on slow boat via China )
HALO1
2009 - 2014 F150
Oct 28, 2015 04:34 AM
Vlitefun
All Things Towing
Jul 3, 2015 08:55 AM
Homerunking2394
Apr 22, 2015 11:15 PM
F2250crew
Oct 21, 2014 04:39 PM
billybobzia
2009 - 2014 F150
Jun 10, 2014 04:53 PM
