429 High Compression Low Power
Old Jan 2, 2007 | 12:09 PM
catbird7's Avatar
catbird7
I have a 1969 429 (ThunderJet) installed in a 1974 F250 4x4. When I bought the engine, I was told it didn't have very many miles on it however I was determined to rebuild it. After disassembly, I found the low mileage story to be true. I was able to rebuild the engine using the std bore. Obviously the rings and bearings were replaced as well as the timing chain, oil pump, and cam / lifters. Heads were cleaned / checked and received new valve seals. After installing the engine I was very disapointed with the power! I think the lack of power is due to how the timing has to be sent in order for the engine to run. I have to use premium $$ fuel (92-93) octane. It still pings sometimes and wants to "diesel" when shut off. What can I do to reduce the high compression? I'm ready to buy a set of "smog" 460 heads from the mid seventies and toss the DOVE C headache. HELP PLease!
Old Jan 2, 2007 | 02:08 PM
thesprocket26's Avatar
thesprocket26
It sounds like timing. You even said it needs to be set. Gather the correct tools and get it done right. I have the same engine running DOVE C heads and it does fine on 87.
jmss123
32
Jul 12, 2024 09:39 PM
nut behind the wheel
Apr 21, 2009 06:06 PM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
mgoovaerts
Feb 14, 2004 01:59 PM
13
Apr 13, 2003 09:07 PM
