Ignition control module problems
Old Jan 2, 2007 | 11:24 AM
guy0783's Avatar
guy0783
Ok, here goes. I just bought a 75 F150 Explorer. When the truck warms up after a while it starts cutting out and dies and won't start untill it sits a while. I checked the forum and went with the ig. control mod. The problem is that the one I have tested good. I bought a new one anyway thinking that it might be testing good because it was cold again. Anyway, I put the new one in and let the truck heat up. After about 30 mins. it happened again. I had kept the old module, so, I just plugged it in and the truck started and ran again. That narrows my problem down to the ig. control mod., right? If so, is the new module bad also, or could something be making them get too hot? Thanks
Old Jan 2, 2007 | 01:10 PM
Mil1ion's Avatar
Mil1ion
Is there a space under it when it gets mounted ?
see the space I have under mine ?
I never have IGN module problems.
Old Jan 2, 2007 | 03:42 PM
guy0783's Avatar
guy0783
Just checked, it does have that gap and the new one didn't come with any gel or silicone to put on it to disperse the heat either.
Old Jan 2, 2007 | 04:33 PM
colvere's Avatar
colvere
Engine quites when warm
I have had the same problem with mine and it could be the ignition module but it could also be your pick up module in the distributor. I just purchased a HEI distributor from Bronco graveyard today be cause I am tired of chasing down electrical gremlins in my dura spark ignition.
Old Jan 2, 2007 | 10:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
The DS system is simple. It also works better than the HEI system for a variety of reasons. If the ballast resistor in the coil primary circuit has been bypassed it will overheat the coil and the module. If the coil is shorted it will overheat both also. The first thing to do for a quick test is to take the module, pickup, and coil to the parts store and have them tested. Then if those test good follow the diagnostic routine in the service manuals exactly to the letter and you will find your problem.
Always make sure the ignition module is mounted 1/4" off the fender for cooling. If you need a new module get a Motorcraft module. Most of the other aftermarket modules will fail within 6-12 months. A lifetime warranty won't pay for wasted expensive fuel. Many of the Motorcraft modules in junkyards are perfectly good and shouldn't cost more than a few bucks. Have them tested at the parts store.
Old Jan 3, 2007 | 04:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thumbs up
^^^^^THIS IS EXCELLENT ADVICE^^^^^ What kills more modules is HEAT...the modules with the plastic RED square (Modules were color coded for easy ID'ing) are the most affected (at least this was true in 1977-79). Ford finally woke up in 1987, moving the modules back down the left fender apron, where they were out of the direct flow of engine heat.
Old Jan 3, 2007 | 04:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
That module spacing tip was in a Ford TSB that I can no longer find.
Old Jan 3, 2007 | 04:32 AM
NumberDummy
Lightbulb
You beat me to it.. ..I was going to type basically the same info you gave.
I have no idea what the TSB said, I DO remember all the problems we had in 1977, shortly after the red modules (D7AZ-12A199-A) were introduced. Ordering new ones was impossible as they were D99...the dreaded Back Ordered-Detroit code. I scrounged local junkyards for used ones to keep customers cars on the road.
Old Jan 3, 2007 | 06:02 AM
Torque1st's Avatar
Torque1st
Posting Legend
I still scrounge the Junkyards for Motorcraft modules. Surprisingly I have never found a dead blue grommet unit. The aftermarket modules are all junk. Nobody seems to have been able to reverse engineer the Ford DS unit.
Old Jan 3, 2007 | 06:10 AM
NumberDummy
Thumbs up
The blue modules (D9VZ-12A199-A) were the most trouble free. The ratio of red vs blue modules sold: 100-1.
Old Jan 3, 2007 | 09:04 AM
guy0783's Avatar
guy0783
My grommet is green, I don't guess that's too common. Is that a bad thing? I can take the module and coil to the parts store and have them checked easy enough, but I am not really sure what/where the pickup is or how hard it is to get on/off.
Old Jan 3, 2007 | 10:54 AM
Mil1ion's Avatar
Mil1ion
There is also a Brown grommet that applies to these trucks.
Every Motorcraft module I have found has the built in shoes to raise it off the mounting surface.
Old Jan 3, 2007 | 11:15 AM
guy0783's Avatar
guy0783
The new module that I bought also has shoes that keep the body of the module off of the mounting surface.
Old Jan 3, 2007 | 01:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
The only one I have in the shop at the moment is a blue grommet D8 part number and the bumps on the underside would lift it about 1/16".
Old Jan 3, 2007 | 03:47 PM
guy0783's Avatar
guy0783
None of the shops in town seem to be able to test a coil. As they are only about $20.00 and the one I have is probably the origonal (sp?) I will just buy a new one and see if that helps. If not it's not a huge loss and I have a back-up.
