hello again well I replace the turn signal switch with a new one I bought from blue oval well that didnt work either first of all all my lights work when I turn on my headlight switch but when I turn on the right turn signal switch only the front passenger flashes nothing else when I turn on the left turn signal switch nothing turns on when I put on the hazards light on only the front passenger light flashes. what might be the problem at the same time my break lights dont work either I connected everything back mathcing the colors and didnt fix my problems. Anyone might help out at tell me where I cant start troubleshooting
hello again finally got it all this time it was just bad connections to the bulbs one wire was broken going to the rear the other had bad contacts to the bulbs corrusion and rust clean it with wd-40 and everything works turn signals hazards and the brake lights so probably wasnt the turn signal at all but at least I have a new one installed. the only thing now my truck wont start when I crank the key its just clicks thought it was the battery so I replace it with another I had in another car but same thing not sure if its the selonoid or the starter.
hey mil I did that test with the booster cable nothing happen the starter just clicked wouldnt turn over what you say bad starter. if it is is that easy to remove and install
hello well everythings working now lights and starter bad connection at the stater needed a little tightening. looking on ebay for a original steering wheel anybody know where I could find a steering wheel for a reasonable price.
