HPOL Removal Tool
Old Jan 1, 2007 | 04:37 PM
Olddog66's Avatar
Olddog66
HPOL Removal Tool
Can someone give me the dimensions of the high pressure oil line removal tool and an idea of how to pop off the lines from the HPOP. I ordered the o-rings and I need to make the tool to pop off the lines. All I really need is the dimensions of the notch.
Thanks
Old Jan 1, 2007 | 07:54 PM
dcwhipple's Avatar
dcwhipple
Olddog,
I used the chuck wrench that came with my router. It's 1/8" thick and the opening is 9/16" and it worked like a champ. I used a thin screwdriver to initially seperate the rubber from the fitting so as not to trash the rubber ring too badly.
Good Luck!
Dan
Old Jan 1, 2007 | 08:01 PM
vloney's Avatar
vloney
Thanks
Get the tool that releases ford clutch slave cylinder lines, its the same size.
Old Jan 1, 2007 | 08:10 PM
Olddog66's Avatar
Olddog66
Smile How hard is it to pop them off?
Do you slide the tool between the mating surface of the oil pump and the line and just pry up? How hard is it to pop the lines out? Any info would help on the first attempt.
Old Jan 1, 2007 | 08:25 PM
vloney's Avatar
vloney
You push back the rubber, that releases the internal clips.
Old Jan 1, 2007 | 08:35 PM
Olddog66's Avatar
Olddog66
Thanks
I get it. Thanks...I had no idea how they came out.
Old Jan 3, 2007 | 01:32 AM
toolboxjunky's Avatar
toolboxjunky
Wink caution
be very careful installing fitting back into the high pressure oil pump use loctite with the ford fitting o-ring kit and torque to specs. always hand tite might be to tight and strip threads out of high pressure oil pump or loosen the threads enough that the pressure will blow the line out and you will be putting a high pressure oil pump in and cleaning and big mess
Old Jan 3, 2007 | 03:51 PM
Olddog66's Avatar
Olddog66
Thanks
I have some information that states the torque should be 34 Nm or 25 lbft. I have the kit and the Loctite 680 so hopefully this will go well. Thanks for the help.
GregN
Oct 3, 2025 03:53 PM
Thomas White
Jul 11, 2015 01:25 PM
Grinder Man
Oct 10, 2014 09:35 AM
pcctim
Apr 14, 2009 11:45 AM
Ranger522
Jul 18, 2004 10:14 PM
