spare removal
Old Dec 31, 2006 | 12:09 PM
Shovelhead 93's Avatar
Shovelhead 93
Question spare removal
How do I get the spare down on a 95 explorer?
Old Dec 31, 2006 | 12:35 PM
kevin74656's Avatar
kevin74656
If you look just above the rear bumper, you'll see a small hole (might be easier to see with the rear hatch open). Under the rear seat you should find a metal rod. Take the jack handle, which you'll find in the compartment on the left side of the cargo area, and assemble it to one end of the rod. The other end of the rod goes into the hole.
Crank the rod counterclockwise, and the spare tire will drop down. You might want to wear gloves, as the spare will be covered in grime.
Old Dec 31, 2006 | 02:33 PM
Shovelhead 93
thanks I checked and dont have the handle just the bar,which end goes into the hole
Old Dec 31, 2006 | 06:27 PM
kevin74656's Avatar
kevin74656
Only one end of the rod will fit in the hole.
The jack handle is also your lug wrench - I should have mentioned that. If you don't have the lug wrench/jack handle, you won't be able to lower the spare or remove the lug nuts if you have a flat. Go to the junkyard and get one, it won't cost that much.
Old Jan 2, 2007 | 08:48 AM
mason's Avatar
mason
Do not rewind the crank without the spare attached. It will jamb up and you will have to replace it. I know from firsthand knowledge.
Mason
Old Jan 2, 2007 | 09:06 AM
marragtop's Avatar
marragtop
Also, once you get the spare down, I suggest lubricating the cable and assembly.
TrikeDawg
Aug 30, 2019 08:04 AM
fletch
18
Dec 1, 2016 09:44 PM
midsouth
Feb 13, 2012 01:08 PM
bkuuz1
Nov 13, 2010 10:14 AM
thepitshop
Sep 9, 2008 08:49 PM
