Aih Code
Old Dec 31, 2006 | 12:49 AM
bigtorque's Avatar
bigtorque
Aih Code
does unplugging the AIH to install my boost fitting throw the SES. or is it a
light code like the unpluged EBPV with no SES.
THANKS.
Old Dec 31, 2006 | 01:11 AM
GREGROB's Avatar
GREGROB
It will not throw the SES light.
It will throw a 'soft' code.
That can hamper some diagnostic tests, but otherwise should be unnoticeable.
Old Dec 31, 2006 | 01:13 AM
bigtorque's Avatar
bigtorque
thanks greg, did you unplug yours, just wondering how you knew.
Old Dec 31, 2006 | 01:18 AM
GREGROB's Avatar
GREGROB
Yep, 86'd mine.
Has never thrown an SES light, but is there when I scan for codes in Auto Enginuity.
Old Dec 31, 2006 | 08:15 AM
Uzumati's Avatar
Uzumati
One of our sponsors sells an eliminator for the code, it is a "Resisted Wire" that runs from the relay to the groung lug for the IAH element that fools the PCM into thinking the IAH is still working.
http://www.puredieselpower.com/catal...541-p-109.html
Old Dec 31, 2006 | 11:02 AM
jtharvey's Avatar
jtharvey
I've built two differnt "resisted" wires for mine to eliminate that code, and both ended up failing. So, I just dont' have one at all. There's really no need for it. The PCM won't do a darn thing any differently if the AIH is working or not, other than throw a code.
Kind of makes you think - if it takes the PCM throwing a code to tell you it's not working, is it really doing that much in the first place?
Old Dec 31, 2006 | 11:12 AM
bigtorque's Avatar
bigtorque
thanks all, i dont guess i need the resisted wire,
much appreciated.
Old Dec 31, 2006 | 12:37 PM
CSIPSD's Avatar
CSIPSD
I bought the wire... and still get the code... Dont waste your $$$
