One of our sponsors sells an eliminator for the code, it is a "Resisted Wire" that runs from the relay to the groung lug for the IAH element that fools the PCM into thinking the IAH is still working.
I've built two differnt "resisted" wires for mine to eliminate that code, and both ended up failing. So, I just dont' have one at all. There's really no need for it. The PCM won't do a darn thing any differently if the AIH is working or not, other than throw a code.
Kind of makes you think - if it takes the PCM throwing a code to tell you it's not working, is it really doing that much in the first place?
