body question
Old Dec 30, 2006 | 02:13 AM
fordfanwv's Avatar
fordfanwv
body question
i have an 89 f150 4x4 and i have two questions
1 is i would like to put a 96 front clip on the truck
2 my upper wheel archs on both sides are bad were can i get some
replacement pannals for it cheap??????????
Old Dec 30, 2006 | 11:45 AM
F250FarmBoy's Avatar
F250FarmBoy
What do you think is considered cheap? Did you check out your local junk yard? The ones around here aren't too bad priced. LMC has rear upper wheel arch panels for $40.
Here's a link: http://lmctruck.com/icatalog/fd/0023.html
Can't help you out on the front clip swap.
Hope that helps.
Old Dec 30, 2006 | 12:14 PM
havi's Avatar
havi
I'll have the Roast Duck
FWIW I put an 89 body on an 83. The front frame horns where the new style bumper mounts had to be modified. This was to make the front clip line right. The body mount locations were good. So I would think the same goes for the 96 to 89. If the bumpers are the same, it shouldn't be difficult. Try the 87-96 forum?
TAT2DUP81
Jan 5, 2013 08:21 PM
moostadon
May 26, 2011 04:09 PM
carlos4x4sand
1997 - 2003 F150
Dec 2, 2005 06:07 PM
19Seventy7HiB0y4x4
Jan 22, 2002 08:38 PM
