body question
What do you think is considered cheap? Did you check out your local junk yard? The ones around here aren't too bad priced. LMC has rear upper wheel arch panels for $40.
Here's a link: http://lmctruck.com/icatalog/fd/0023.html
Can't help you out on the front clip swap.
Hope that helps.
Hope that helps.
FWIW I put an 89 body on an 83. The front frame horns where the new style bumper mounts had to be modified. This was to make the front clip line right. The body mount locations were good. So I would think the same goes for the 96 to 89. If the bumpers are the same, it shouldn't be difficult. Try the 87-96 forum?
19Seventy7HiB0y4x4
01-22-2002 08:38 PM
