hey ive got a 98 ford ranger xlt with problems with the head lights... high and low beams not working, temporary lights working as well as the running lights. fuses are good, bulbs, relay and switch. no power to left or right headlamp fuses... any help is needed and im outa ideas.
Welcome.
The headlamp circuit on your '98 starts at the #12 fuse located in the fuse box under the hood. This 30A fuse feeds power to both the multifunction switch (MFS) and the main light switch by virtue of a DB/O wire.
The main light switch itself also provides power to the MFS (R/Y wire) according to the position of the switch.
The MFS, in turn, feeds power to fuse # 33 (GY/O wire) and fuses #4 and #8 (R/BK wire) which are located in the fuse box inside the cab.
Did you try "flash to pass"? If that works,you could have a problem in the multi-switch.The fuses/circuit breakers are before lights,switches etc.,if there's no power there,your problem is probably there.
