265/75r16 on a dually??
I stopped by the Firestone guy tonight, and asked about bigger tires for my 99 dually. I know most folks say the biggest you can go is 255/85, but i wanted to see what he said. He then called a friend, and his friend say as long as I keep them aired up, I can get by with a 265/85 without spacers. He said he does them all the time...Is he feeding me bull, or can I use these without worrying about rubbing? I could always through a 1/4" spacer in I guess....
Thanks!
PS- does Costco save you much on tires?
Thanks!
Here's my .5 Cent (that's the best I can do). A stock 235/85/16 is a 9.3" wide tire. A 265/75/16 is a 10.4" wide tire. The distance between the sidewalls of 2 rear tires (1 stock steel, 1 stock alloy, off of the vehicle, flat on the ground, inflated to 65 psi) is 1 5/8". So with the 265/75's you will have closed the gap between the tires to about 1/2" unweighted. Add the weight of the vehicle and the tires will come even closer, maybe a 1/4" at most. That leaves the tires at 1/4" apart. My gut feeling is that is way to close, but it's only a gut feeling and since I've never had my dually wheels that close, or known anyone that has, I really can't say what problems you might encounter. I run 35x10.5 tires on custom 16x7 wheels in the rear w/a 2" bolt-on spacer, so unfortunately I can't just go out and take a few measurements to give you a better idea, I would if I could.
Enviro, since my truck is currently in the shop- do you remember how much thread is sticking out past the lug nuts on the rear tires? I see a guy on epay selling a set of 4 5/16ths shims for around $30, I figure two in between the rears and two in the front to keep the tires a bit further away from the springs?
4x4countryboy
01-03-2018 05:05 AM
jr2000sd
13
12-19-2016 10:49 AM
ufvj217
11-01-2015 07:16 PM
