Heating problems
Old Dec 28, 2006 | 02:01 PM
jokerswild130's Avatar
jokerswild130
Question Heating problems
My expeditions heating system is not working properly. Though it blows air normally it only heats in the back, in the front it still blows cool air, even when its set to the highest. any suggestions?
Old Dec 28, 2006 | 02:04 PM
Doug63's Avatar
Doug63
Is it a manual or automatic temperature control system? If it's the automatic system, from my researches on these boards, you might have a broken blend door or blend door actuator. Do a search on blend door and you may find the answers you seek.
Good luck!
Old Dec 29, 2006 | 12:47 PM
wavinwayne's Avatar
wavinwayne
Since winter of '05, I'd had the front no-heat problem in my '97 Expedition. Last week, I had my mechanic flush the front heater core. Completely solved the problem. Total cost = $65
Hope that helps.
Old Dec 29, 2006 | 08:28 PM
jrod8382's Avatar
jrod8382
I had the front heating problem in my '99 EXP. Had to have the dash removed to replace the door flap that allows the hot air in. I first had the heater core flushed and trouble shot the cold/hot dial to make sure it was working properly, replaced the water pump, thermostat and radiator before I had the door replaced, at the cost of $400 at a shop for removing the whole dash, this was 2 years ago and now this year I am not getting heat at the front or back and already had the truck in the shop to have the coolant system flushed. So I took over the '99 and bought my wife an '04. I have invested about $1000 in my heating system. Go to a parts store and buy you a couple of electric heaters that plug into the 12 volt power ports.
Old Dec 30, 2006 | 09:39 AM
sbclemens's Avatar
sbclemens
Make sure you don't have a bubble in the coolant system. Also check your thermostat.
Old Dec 31, 2006 | 12:07 PM
jokerswild130
ok, thx for the info.
ldou0110
47
Dec 12, 2014 10:44 AM
ap4u06
Mar 18, 2011 06:06 PM
SmokinGun
Feb 16, 2008 02:34 PM
stangz
Nov 21, 2002 10:52 AM
wesgall
Dec 19, 2000 12:26 AM
