Sponsored by: Real Truck
'99 250 v-10 Started!!!
Old Dec 28, 2006 | 01:42 PM
jims99's Avatar
jims99
Smile '99 250 v-10 Started!!!
For those of you that read my earlier post..I searched hi and low for the problem.I first looked at the fuel system>saftey shut off,pump,filter,injectors,pressure,no luck there..Next I started looking for a spark,none was found,so I had to start looking at sensors,after looking at everything I could find and getting very dirty i.e.(was stuck in some mud.) I noticed a large amount of mud under a/c compressor and packed between compressor and block,started digging in there and found the problem....
The wire plug to the crankshaft position sensor had been damaged,made a temporary repair and vooooom,it started with no problem. Now to get the soldering gun out and fix it right.
Untill next time...Thanks Jim
Old Dec 28, 2006 | 02:07 PM
redford's Avatar
redford
FTE Leadership Emeritus
I love it when the repairs are cheap!
Old Dec 28, 2006 | 02:24 PM
PHWLEE's Avatar
PHWLEE
I did read your other posting and was thinking about some sort of water infiltration into the electrical system, coil getting wet, that sort of thing. It's good you found the problem.
Boatbum01
13
Oct 10, 2010 08:57 PM
Boatbum01
Jul 4, 2010 11:40 PM
CIRCLEBFAB
May 31, 2008 10:34 PM
jim6liter
Dec 4, 2007 02:17 PM
jimhay
Dec 8, 2003 12:34 PM
