TS performance or DP performance Chip?
Old Dec 28, 2006 | 12:03 AM
CSIPSD's Avatar
CSIPSD
First I have to ask what year is your truck? If it is a 01 or newer I would stay away from the pain... YOu have PMR's- Powdered Metal Rods. They were installed in the 7.3 from 01 on. They dont like the CP's (cylinder pressures) that ProPAIN causes and will walk off the job, leaving you with a rather large hole in your block.
OK, If you can and want to return the Snows Water injection. Nothing wrong with there kits, I am running there stage 2. But there stage 3 is a joke, looks like crap and is way over priced! Go to www.coolingmist.com and look at there stage 3 kit for diesels. It comes with a PDA similar to the Banks system in the 6.0. Very nice unit!!!
You need to install the pyro PRE turbo, there is no "limit" on a post turbo pyro. If you install it there you are wasting a gauge... It will vary from as little as 0 to as much as 300 degrees. Its really easy to drill the manifold and tap it, or drill and clamp on the up pipes. Pre turbo max is 1250 for any extended time. You can top 1500 for a few seconds passing or on the strip but not for more then 15-20 seconds.
As far as the turbo mods... How far do you want to go? I started with a WW (wicked wheel) and then added an ATS housing... then a Turbomaster wastegate control... guess what? I still upgraded to a new turbo... Just plan ahead and buy accordantly.
You didnt have a intake listed... I would recomend the AFE stage 2... Best out there by FAR...
If you need any help feel free to Pm me... I have installed 20-30 gauge sets, 10+ turbos, injectors... What ever you might need.
Old Dec 28, 2006 | 07:19 AM
dzzavid's Avatar
dzzavid
i have a late 99 thank god... i havent even taken the snow boost cooler out of the box yet but that is dissapointing to hear that it is a peice, i paid liek 700 for that thing! i will see if i can return it.
thanks for your suggestion on the pyro
as far as the turbo , i am prob just going to replace the whole unit so i am not goign to put any more money into that for right now, i think the wastegate and turbine wheel were like 400 so i am goign to do that for now and upgrade the turbo after a while.
thank you very much for your help and sugggestions!
Old Dec 28, 2006 | 07:27 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Turbine wheel? Or intake compressor wheel? The compressor wheel can be found as cheap as $60 and they are all the same. The wastegate actuator can be remedied for free by removing it and tightening the turnbuckle, efectively shortening it and adding spring seat pressure. How much did you pay for those? Return the water injection and spend that $700 on a $400 1.15 exhaust housing, and a $400 intake compressor shroud, and return that compressor wheel for however much you paid. That turbo then should be enough to suit any mod to a truck with stock injectors, and even support stage 2 injectors.
Old Dec 28, 2006 | 07:41 AM
dzzavid's Avatar
dzzavid
compressor wheel, my bad on that, i did not relize that i could do that for the wastegate, thank you
sounds good to me thanks for the advice!
Old Dec 28, 2006 | 09:52 AM
CSIPSD's Avatar
CSIPSD
Gotta have the water man...LOL Once you start using it, its hard to stop...HEHEHEHe
Old Dec 28, 2006 | 09:56 AM
dzzavid's Avatar
dzzavid
cant wait to put it in..
i think i will be refilling my tank like 3 times a day when i first get it in.. haha
Old Dec 28, 2006 | 09:58 AM
CSIPSD's Avatar
CSIPSD
I just dont like the controler on the stage 3... It looks like something out of a WW2 Air plane...
Get the 8 gal res if you do install it. I can run about 300 miles with the water on full time and 8 gal. Over 800 if I just turn it on in the hills.
Old Dec 28, 2006 | 10:03 AM
dzzavid's Avatar
dzzavid
ok cool , do you have the stage 3? i dotn know if i want to spend the extra 400 just to have a PDA..
also does this replace my current EGT gauge? or does it tap into it?
Old Dec 28, 2006 | 10:14 AM
dzzavid's Avatar
dzzavid
because if that is goign to replace my autometers i am going to have to go with the PDA
is there a big performance difference between the 2?
Old Dec 28, 2006 | 10:26 AM
CSIPSD's Avatar
CSIPSD
I think the Cooling mist will work better then the snows. With a digital processer and a more precice looking piece. I a going to change out my injectors for theres in the next few weeks. There's are cheaper and can flow more water with better atomization.
Old Dec 28, 2006 | 10:37 AM
dzzavid's Avatar
dzzavid
i might just have to go through tth epain of sending the snows back and getting the cooling mist one..
Old Dec 28, 2006 | 02:20 PM
79CEEJAY's Avatar
79CEEJAY
I would go with DP also...as a matter of fact I did. Before I had my '02, I ordered a TS then before I even opened the package, bought the '02. I sent the chip back unopened per their return policy, and they clipped my refund for over $100.00 for a restocking fee. They did not care that it was in the original box unopened. They would not give me a full refund. I even tried to offer them a reasonable restocking fee, but they stood hard behind I believe it was a 30% fee. I guess they want to teach paying customers a lesson. I DID learn a lesson.....don't deal with TS Performance. Go with DP....Jody is a GREAT GUY! The only regret I have is that my chip blank is not an F5, but in fact a TS.......thats just the way it goes I guess. I am sure many people are happy with TS, but I feel I was not treated fairly and guess I have a bad attitude because of this......besides Jody's tunes are MUCH better.
nossliw
29
Apr 12, 2012 08:58 AM
f-250diesel
Jan 21, 2010 10:55 PM
mxracer3276
Sep 3, 2009 04:15 PM
Adirondacker
13
Apr 9, 2008 04:46 PM
FordGuy0131
Aug 3, 2007 12:22 AM
