identifie this trans
Old Dec 27, 2006 | 01:50 PM
wozxxx86's Avatar
wozxxx86
ok im tryin to identifie the trans in my truck. on the truck is says I for the trans code, i know its an AOD, but i wanna know weather itsa aod or aode?
please help..
thank you
Old Dec 27, 2006 | 02:00 PM
steveo88's Avatar
steveo88
if it has a electric od delete it is aode if dosnt it is aod
Old Dec 27, 2006 | 02:02 PM
Kemicalburns's Avatar
Kemicalburns
its an AOD. they didnt install electronic controlled trannies till late 89/90
Old Dec 27, 2006 | 02:03 PM
adrianspeeder's Avatar
adrianspeeder
Easy, no AOD-E in the trucks/bronco!
'85-'93 could have the AOD (trans code T, there is no I) and a display of PRN(D)D1
However '94-'96 F-150s could have the 4R70w, which replaced the AOD-E in the cars, but the plane ole mechanical AOD is what you have.
Adrianspeeder
Old Dec 27, 2006 | 02:07 PM
wozxxx86's Avatar
wozxxx86
ok. now hears why i asked, i swaped out my e4od to the aod with xfer case, cause my e40d was gettin ready to take a crap. now that i got the trans in the truck it wont shift outta first gear, im also havein a hell of a time gettin all the fluid in the converter. so the other question is will low fluid keep it in first?
Old Dec 27, 2006 | 02:08 PM
wozxxx86's Avatar
wozxxx86
fergot the new truck is a 93 f150
Old Dec 27, 2006 | 02:11 PM
adrianspeeder
How did you set up the TV cable?
Adrianspeeder
Old Dec 27, 2006 | 02:14 PM
wozxxx86's Avatar
wozxxx86
it was set the same as it was in the other truck. lettin off of the gas doest make it shift either. the tranny worked perfect befor the swap
Old Dec 27, 2006 | 10:11 PM
wozxxx86's Avatar
wozxxx86
ok the tv cable is ok and the fluid level is right where it should be, yet the tranny still wont come out of 1st gear????
Old Dec 27, 2006 | 11:50 PM
wozxxx86's Avatar
wozxxx86
ok, now i got it to shift, it was a sticky tv valve. now it wont kickdown when more throttle is applied.
Old Dec 28, 2006 | 01:19 AM
fonefiddy's Avatar
fonefiddy
Replace the TV cable and make SURE it's adjusted properly. It wont last long out of adjustment.
Old Dec 28, 2006 | 06:18 PM
wozxxx86's Avatar
wozxxx86
ok, i just flushed the tranny, and it shifts fine in 1-2 but 3-od is inconsistant. also i still have no down shifts. think it would be as simple as a tv cable? the one i have works fine, glides no binds in movement. ima try adjustment
Old Dec 28, 2006 | 06:22 PM
wozxxx86's Avatar
wozxxx86
some one posted how to adjust the tv on this post. now i dont see it. my haynes doenst specifie how to adjust mine, it only includes threaded tv's
