Fuel gauge sender test
Old Jan 19, 2010 | 09:17 AM
Tom108's Avatar
Tom108
I have a 1990 E-150, does anyone know the Fuel sender resistance values?
Old Jan 20, 2010 | 07:13 AM
subford's Avatar
subford
Open circuit above "F" (pegged).
145 ohms Full.
22.5 ohms Empty.
Short circuit to ground below "E" (pegged).
Old Jan 20, 2010 | 09:42 AM
Tom108's Avatar
Tom108
Thanks for the info subford. First thing I will check is the ground(s), I 'm assuming they
should be somewhere near to or on the tanks or close on the frame? On the(your) schematic it says "Left Fender" did they run the ground(s) wire back up to the front? By the way nice job on the schematic if that's yours! And thanks for posting it!
Old Jan 20, 2010 | 10:33 AM
subford's Avatar
subford
Originally Posted by Tom108
Thanks for the info subford. First thing I will check is the ground(s), I 'm assuming they should be somewhere near to or on the tanks or close on the frame?
No the ground will not be near the tanks and the frame is not a good ground.
Yes they ran the ground all the way back to the LH fender.
I have no idea what schematic you are looking at as I have posted many schematics and I did draw a lot of them but do not know if I drew the one you are looking at.
hharris8
Mar 24, 2017 06:13 PM
Whitey Ford
Sep 29, 2016 09:33 AM
scottlathrop
Sep 28, 2016 06:33 AM
baverwolf
Mar 13, 2016 11:22 AM
PRIMERED79 SHORT BED
Sep 5, 2013 09:52 PM
