power locks and windshield wiper code??
on
i have cleared my codes with my AE be for my trip..as some of you know i had some prety strange ones..i just scanned it again and my power lock and un lock and my wiper and washer is still flashing a code...every thing seems to be working fine...i havent had any problems with any of these things...can any one tell me why these code keep coming up....my other codes have not shown back up....
on
thanks alan..no ses light every thing works good never a problem that i have seen..im off to gator land right now ill check back tonight..
<TABLE borderColor=#bebbbb cellSpacing=0 cellPadding=2 width=750 align=center border=1><TBODY><TR><TD align=middle width=50>B1300 </TD><TD align=left width=550>Power Door Lock Circuit Failure </TD></TR></TBODY></TABLE><TABLE borderColor=#bebbbb cellSpacing=0 cellPadding=2 width=750 align=center border=1><TBODY><TR><TD align=middle width=50>B1310 </TD><TD align=left width=550>Power Door Unlock Circuit Failure </TD></TR></TBODY></TABLE><TABLE borderColor=#bebbbb cellSpacing=0 cellPadding=2 width=750 align=center border=1><TBODY><TR><TD align=middle width=50>B1450 </TD><TD align=left width=550>Wiper Wash/Delay Switch Circuit Failure </TD></TR></TBODY></TABLE>
Ron need a little more info
1300 & 1310 Do all of the door switches and locks work?
Do you have factory keyless entry and does it work?
If keyless entry does panic button on remote work?
1450 Does the wiper delay work correctly?
Do wipers function correctly on all settings?
Does the Wash/Wipe work?
One condition common to both symptom charts is fuse 15 under the dash bad causing no communication to the GEM.
on
on
The chime can be disabled, it may have on yours.
If everythings working i'm thinking its a communiction issue with the GEM.
I'll email you the pinpoints so you can look at it when you get back.
Ever fix it, Ron? I have those "codes"... not the same code for the wipers, but still a code. Sometimes it's wipers, sometimes it's horn... it's more fickle than a girl! Are they all on the same fuse/relay? Here's a screen shot:
I also never had the seat belt alarm either... I don't think I've even seen the indicator! Something to be said there?
Note, the boost code is because the red line is pulled and the AIS codes are because it's a '00 NVK4 PCM in an e99 truck. Not sure on the P1670, though... I hear the P1249 is just one of those menace codes. I think my valve is screwed because even with the line plugged in, sometimes I could still make 22lbs of boost and other times I could hardly make 13 so, I suspect a relation there.
But yeah, back to the original topic... what'd you find out?
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
04-26-2016 05:50 AM
