Cam Upgrade
Old Dec 29, 2006 | 01:21 PM
Conanski's Avatar
Conanski
Originally Posted by Jrock909
Will I need to convert over to roller lifters and everything on the block to get that cam to work? If I do already have a roller cam would that mean that I already have roller lifters...?
The thing that makes a roller cam different from a flat tappet cam is the lifters. A roller cam uses roller tipped lifters, there are no rollers on the cam itself, the only real difference with it is how it's finished. On a flat tapped cam the lobes are unfinished, just a rough casting, only the bearing surfaces are polished. On a roller cam both the bearing and cam lobe surfaces are polished. This is to give the roller lifters a smooth low friction profile to follow.
P.S. And yes, you already have roller lifters.
dzjammer
Mar 31, 2009 07:14 PM
rangermann17
Dec 26, 2008 07:49 AM
f100guy
Sep 2, 2008 07:33 AM
powderspecial600_98
Jan 11, 2006 10:52 AM
cjcathey2002
Aug 13, 2002 09:02 PM
