Does anybody know what this code means? I retreived it with the SCT but it didn't give me any other info, I cleared it and it came back about 200 miles later. One time was pulling an empty car dolly over Wolf Creek Pass, and the other time was pulling a Toyota pickup on the dolly over Monarch Pass. Thanks
Kw is right, its turbo underboost. Chances are it either needs cleaned, replaced, or you have egr issues. Sometimes the vgt solenoid can drag that one up. Kind of surprising there is no p132b with it.
Don't forget P0299 can also mean overboost. Could be your tuner causing excessive boost.
SCT calibrates the desired exhaust backpressure tables and MAP desired tables to match what the duty cycle feedforwards and control loop actually produce, so assuming the turbocharger is functioning properly, this shouldn't be an issue.
Does the tune you are running have the "Exhaust Brake/Aggressive Tow Haul" strategy enabled? Some calibrators max out the desired EBP to match the limiting scalars at low/closed throttle to force the turbo closed, which can cause this code. If not, I would look for EGR or Turbo issues.
No, it could be valid, but assuming that he does not have the added exhaust braking in his aftermarket calibration, you wouldn't get that code simply from the added boost from the SCT, since the PCM is recalibrated for it and thats what it is expecting to see.
Turbo or EGR malfunction, or half-*** calibration could still be valid causes.
I do have the aggressive tow with turbo brake, but it did it when I was driving up the pass, not down. Is that still a possibility? Do I need to worry about it? I've been driving it since I got back in town on Sunday, and the check engine light has not come back on.
there is one way to rule out the tuner. remove it. if the code comes back it is a base issue. i see that you have a 06. these later years are more sensitive to under/over boost and will throw a code due to emmission strategy.
I haven't seen this much on '06 trucks, but earlier trucks would set P0299 when the EBP sensor was biased. Check the KOEO PSI reading from the EBP. Should be atmospheric pressure for whatever altitude you're at.
I think that I will wait and see if the engine light comes back on, unless you guys think that it could be something major. I love my truck and don't want to hurt her!
