heater fan
Old Dec 26, 2006 | 08:26 AM
2001gocougs's Avatar
2001gocougs
heater fan
I am looking at replacing the heater fan control in the dash, because it will run on high if I throw the switch a few times. No other speeds of the fan will work. Do you think I am headed in the right direction?
Old Dec 26, 2006 | 11:57 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Do you have just the standard heater, or do you have factory A/C as well?
I would guess it is more likely the blower motor resistor is bad.
When the switch is on high, it bypasses the resistor altogether.
Old Dec 27, 2006 | 06:58 AM
2001gocougs
I have the factory heater with factory air. Is the resistor able to be replaced without replacing the whole motor?
Old Dec 27, 2006 | 07:37 AM
locknkey's Avatar
locknkey
Fan Switch needs replacing. You can buy one at NAPA stores, or other Auto Parts Retailers. They cost around 15.00. Just remove the old and replace with new...
Old Dec 27, 2006 | 01:39 PM
81-F-150-Explorer
Yes the heater resistor is able to be replaced seperately.
I just reread your first post and I must have missed the "Throw the switch a few times to make it work on high" part. This does suggest a switch may be needed.
Before replacing anything, I would test them first however.
Remove them from the power connector and hook them up to a voltmeter set to ohms. This way you can tell exactly what you need. You may need a switch and resistor. Or just one or the other.
DavidKing
Large Truck
Oct 10, 2016 10:48 PM
easyridin
16
Jan 13, 2016 05:37 PM
Zooker89
1961 - 1963 F100 Unibody
Aug 5, 2014 08:14 AM
ckutter
Mar 23, 2014 10:02 AM
dmccorkle911
20
Jan 6, 2014 09:34 PM
