General Automotive Discussion
01 Impala LS problem
Old Dec 25, 2006 | 09:49 PM
jbullfrog's Avatar
jbullfrog
Question 01 Impala LS problem
My wife's Impala has an odd problem. The electric cooling fans are turning on ans staying on. I have had to pull the fuses twice in the last month. It has been 30 degrees or below both times I have been driving it that this happened. The dealer had no idea what would be causing this. Anyone here have an idea?
Thanks,
Old Dec 25, 2006 | 09:52 PM
thefarelaneman's Avatar
thefarelaneman
The fans have to be controled by a temp sensor somewhere........Find the sensor and check it out.The dealer should be reported for being incompentant
Old Dec 29, 2006 | 01:17 PM
385seriesHemi's Avatar
385seriesHemi
Yeah Farelaneman is right about the sensor. Generally the coolant temp sensor is also the fan switch one in both so check that. Check all-data at a library if possible. Ummm I wouldnt know where else but begin there for starters. It might even be a bad connection also.
53rat
17
Jun 13, 2011 01:10 PM
PRO49FORD
Dec 28, 2009 03:31 PM
tonyss96dcm
13
Jan 15, 2009 12:40 AM
bodabdan
Apr 13, 2005 08:42 PM
tonyss96dcm
Aug 5, 2002 10:53 AM
