flathead C8BA with merc heads
Old Jul 12, 2001 | 10:01 AM
cdwyer's Avatar
cdwyer
My block C8BA has what I determine to be Merc heads (8CM)
Does anyone know if Ford and Merc heads were the same and interchangable, or could it be a 255 engine?
There is also a tag that states the engine was rebuilt by "Precision Machining in Toronto an authorized Ford rebuilder." This may account for the fact that it is a '48 block in a '53 F100.
Thanks
Chris
Old Jul 13, 2001 | 01:10 AM
mtflat's Avatar
mtflat
Chris,
Ford and Merc heads are interchangeable, but are not the same. Different years have different compression ratios - depends on the depth of the cutout over the piston and valves.
If you're asking if they could put Merc heads on a Ford, the answer is yes, but with an 8CM block I'd say the odds are in your favor that its is actually a merc.
The only way to verify this is to pull a head and measure the stroke from top of the block to the bottom of the piston travel. If 4" then you have a merc crank, but 3 3/4" and its a Ford crank.
Old Jul 14, 2001 | 04:30 PM
Franklin2's Avatar
Franklin2
DougAdams
Jun 26, 2017 09:35 PM
50mercman
13
Sep 14, 2016 09:33 AM
merc460
Ford Truck Parts for Sale
Mar 22, 2016 07:18 AM
52 Merc
Nov 3, 2015 09:54 AM
40yearvet
23
Nov 18, 2007 08:52 AM
