Sponsored by: Real Truck
REGULAR Cab, SHORT Box?
Old Dec 24, 2006 | 05:01 PM
Beast12's Avatar
Beast12
Question REGULAR Cab, SHORT Box?
I have been pondering this a while but keep forgetting to post. How many people out there would buy a SuperDuty truck with a regular cab and short box (6.5 feet)?
I would think there would be some kind of market for it. A big one that comes to mind is snow plowing businesses. That short wheelbase would be great for getting into tight areas.
So, your thoughts?
-Matt
Old Dec 24, 2006 | 05:48 PM
lariat79sc's Avatar
lariat79sc
I'd suspect it would ride pretty stiff if you were empty.
Old Dec 24, 2006 | 06:10 PM
elyrain's Avatar
elyrain
I got a RC LB and it bounces around like a lowrider when it's not loaded.
Old Dec 24, 2006 | 06:16 PM
PHWLEE's Avatar
PHWLEE
In a SD, I would not consider any cab version other than the SuperCab or CrewCab. In fact, the only Regular cab versions of a SuperDuty that I have seen around here are commercially owned ones used soley for work purposes. I guess there really isn't much of a market for 3/4 ton trucks in a regular cab for personal use. Not enough interior room probably even with either size bed.
Old Dec 24, 2006 | 06:18 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Stiff, but QUICK! Short wheelbase means less weight.
Which is why I went with my SC SB.
Old Dec 24, 2006 | 06:26 PM
lariat79sc's Avatar
lariat79sc
With a regular cab shortbox you might bounce sideways and roll before you ever seen how quick it was. That combo has to be a jack rabbit in 4x4 form anyways.
Old Dec 24, 2006 | 06:42 PM
LEVEL10's Avatar
LEVEL10
rc swb is great for plow work and thats about it. a sc swb would do a lot better for the same work plus the ability to take alone 2 more people .if it was say towing a good sized boat, and gear
my personal for both uses was my sc,swb. with a psd or a v10. both do some graet work. beast it was great for both uses.
captchas
Old Dec 24, 2006 | 07:14 PM
Customz's Avatar
Customz
I'd buy one in a second. It would be great offroad with the v10 and 4.30s. Lower cost and less weight as well.
Old Dec 24, 2006 | 07:51 PM
TeamMudd's Avatar
TeamMudd
best place to find one is in an air port maintenance auction!! next time you're at the air port take a look around and i bet you might catch a glimps of one! i guess they are popular in austrailia or something like that! they do make them, amd most of them that you find around the US are imported!
there was a construction company selling off 4 that they had bought from an air port (when the bought new ones). they weren't very practical for construction work with the short bed (the owner said)! he sold those off for some reg cab LB dually's! i tried to get ahold of one or all of them, but he got a larger off from some company in TX! all of them were 4x4 w/ 7.3L's. they had lots and lots of hours, not alot of miles though! i though they'd make a good hunting/mild duty farm truck!
Old Dec 25, 2006 | 09:27 PM
bbender85's Avatar
bbender85
unless you want to be different. i happen to like mine.
i don't need the extra cab space, so why not?
Old Dec 25, 2006 | 09:49 PM
DD1684's Avatar
DD1684
I don't think it'd be a good plow truck. Since the wheelbase would be so much shorter, that sucker's front end would sag immensely (especially if it were a diesel). You'd need some good ballast in the bed. I don't think the reg cabs have anywhere near enough room anyway.
Old Dec 26, 2006 | 04:56 PM
akford351's Avatar
akford351
Reg cabs rock!
Old Dec 26, 2006 | 05:41 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i agree!
i dont think i wwould want a 3/4 ton and up with a short bed
Old Dec 26, 2006 | 06:07 PM
Bdox's Avatar
Bdox
All depends on what you want to use it for. I like it a lot because of the short turning radius. Makes a crewcab feel like an ocean liner by comparison. Best thing ever for off road. Less weight, better milage.
Old Dec 26, 2006 | 06:13 PM
Ford79's Avatar
Ford79
Originally Posted by akford351
Reg cabs rock!
Unless you have a growing family, that is.
