Name that thar rear
Old Dec 24, 2006 | 07:52 AM
fergusonicford's Avatar
fergusonicford
Name that thar rear
I posted this in the Older Bronco and 48 thru whatever forums to no avail thus far....maybe someone here can help me:
I have a '56 project with a Donar Dana Rear End Differential which I would like to Identify and from what vehicle it came from:
Ring Gear is stamped DANA 12 12 58 30 933 A3R41 55-19
I therefore know it is a 2.89 - 1 ratio.
10 bolts on Inspection Cover, no removeable 3rd member, 3 1/2" wide brake shoes, 61 1/4" outside axle flange to outside axle flange.
Any clues?
Old Dec 24, 2006 | 11:43 AM
3Mike6's Avatar
3Mike6
Assume it has the 5 on 5.5 bolt pattern? There's a tech article on rearends a rearend swaps somewhere on FTE.
Old Dec 24, 2006 | 11:51 AM
3Mike6's Avatar
3Mike6
Maybe this will help?
https://www.ford-trucks.com/article/...ial_Swaps.html
Old Dec 24, 2006 | 03:40 PM
fatdan460's Avatar
fatdan460
maybe a 5 lug dana 60 from a heavy half ton. check with the offroad threads. some of those guys have dana spicer code books
Old Dec 24, 2006 | 04:10 PM
fergusonicford
Yes, 5 on 5 1/2.....a fella on the Early Bronco forum asked if it had finned drums....and it does ....and he thinks it is a 62 - 64 HiPo Galaxie as that is what they used.
The article mentioned here gave no clues. appreciate all the help.
Old Dec 24, 2006 | 04:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
WHOA...I didn't say that...I merely pointed out that the early HiPo Galaxies used finned drums.
All the HiPO Galaxies used 9 inch rear ends.
Your Dana 3rd member with the high speed rear end, finned drums and oversized brakes gave me the idea that the rear end you have, may have come from a race car of some sort.
3 1/2 inch wide rear brakes are VERY unusual on any rear end...even a F350 never used rear brakes that large.
Old Dec 24, 2006 | 04:50 PM
mtflat's Avatar
mtflat
Have you seen this Dana ID website? It might be a place to find more info.
http://77cj.littlekeylime.com/Dana44.htm
Old Dec 24, 2006 | 05:37 PM
fergusonicford
NumberDummy.....oops...sorry.....I needed to read your reply more thoroughly.
I stand corrected.
Old Dec 24, 2006 | 05:40 PM
NumberDummy
Not a problem ,Sir.
artscott61
13
Apr 27, 2021 01:10 AM
78 Ford F150 460
24
Aug 15, 2016 03:52 PM
Rancheroracer
EcoBoost (all engine sizes)
Jul 5, 2011 05:46 PM
fontime
18
Nov 28, 2010 12:34 PM
havi
22
Feb 17, 2008 02:57 PM
