hard starting 4.0
Old Jan 10, 2007 | 04:45 PM
  #31
mike0179's Avatar
mike0179
Trouble shooting is going slow do to work and college classes, homework ect. I wont have time to check the pressure untile saturday. I will buy a pressure tester to do the job. How do I check the pressure exactly? Aftrer I put the gauge on the rail I check it with the key on then with the engine running, right? then after I shout the engine off I should see how long it takes to loose pressre.
Old Jan 10, 2007 | 04:57 PM
  #32
pgw85706's Avatar
pgw85706
There is a good procedure in the Tech Info page.
http://fords.kilonet.org/ken00/FuelPressureTesting.doc
Old Jan 10, 2007 | 05:10 PM
  #33
pawpaw's Avatar
pawpaw
Well Mike, you could probably make loan of a fuel pressure test gauge, at your favorite autoparts store. Most have a loan-a-tool program, in which you make a refundable deposit for loan of a needed tool.
Disable the fuel pump, crank the engine until it stops trying to start.
Put your safety glasses on & connect the gauge to the fuel rail test valve port.
Re-enable the fuel pump.
Go to KOEO & read the fuel pressure, note the time & check for pressure drop over the specified time in your repair manual, for your particular engine.
Old Jan 10, 2007 | 06:59 PM
  #34
mike0179's Avatar
mike0179
thanks pawpaw, I'll let you know what I find this weekend
Old Feb 3, 2007 | 05:37 AM
  #35
mike0179's Avatar
mike0179
well, i havent had time to check the pressure yet, but it tried cycling the key several times and it dosent help. I replaced the ect and the iat sensors and that didnt help. I read that the maf could be the culprit. I cleanded it and that didnt help either. I unplugged the maf while the engine was running and the engine hesitated for a instant and ran the same as when it was plugged in, even at all every rpm and under load, when I plugged it back in it did the exact same thing like when I unplugged it. I read that it should change things when unplugged, I read that it could be in limp mode because of the bad maf, there are no codes. thanks
Old Feb 3, 2007 | 07:14 AM
  #36
tomw's Avatar
tomw
You *should* get a code when you run with the MAF disconnected. If not, you may have a defective ECM. You should be able to get a code by disconnecting most sensors as they lose the 5v 'reference' signal back to the ECM and it doesn't like that.
tom
Old Feb 4, 2007 | 07:04 PM
  #37
mike0179's Avatar
mike0179
How long should it take before I get a code after I unplug it? Should there be a change in the engine when its unplugged? Someone told me the computer could be in limp mode were the computer runs off of factory set values.
Old Feb 5, 2007 | 07:48 AM
  #38
tomw's Avatar
tomw
Almost immediately. You should check that you get all the 'OKeyDoke' codes when you run the test. If you get nada, it is brok.
The computer will have a code there if it is running in limp-home mode. But, if it can't tell you it is OK, it may not be able to tell you it is broken.
t
Old Feb 19, 2007 | 11:47 PM
  #39
mike0179's Avatar
mike0179
Well. I finally Took the truck in to a mechanic to see what the problem was and what he discvered was that the person who tunned it up before I purchased it in occtober put plugs that were to cold for the engine. He says that is a common mistakes with ford vehicles done by some mechanics, hes seen it a few times. I hope this will help with those off you who cant find the cause.
Thanks to all of you.
mike
jlarsen513
Nov 14, 2014 05:23 PM
Barney Oldfield
Oct 19, 2010 12:43 PM
mike0179
Apr 23, 2007 07:05 PM
clipper1
Nov 16, 2005 02:16 PM
firedog007
Aerostar
Aug 5, 2003 01:54 PM
