Help finding rattle
Old Dec 21, 2006 | 08:04 PM
BlackFX4Screw's Avatar
BlackFX4Screw
Help finding rattle
Rattle coming from behind rear seat around or just below the window seal. Under where the headrest is. I removed the seat and the felt lining and still cannot find the rattle.
Rattle seems to go along with the shaking of the bed. Like a wire under the bed rail or something.
Any ideas?
Old Dec 21, 2006 | 08:10 PM
smokestone52's Avatar
smokestone52
I have a power sliding window that has an annoying clicking kind of rattle. I am sure that is what mine is because I just barely opened the window and the clicking went away. I am pretty sure it will be an easy fix.
Old Dec 21, 2006 | 08:33 PM
BlackFX4Screw
I had that fixed. There's a TSB out and the dealer will know what you are talking about.
Old Dec 26, 2006 | 01:09 AM
joeypurcell's Avatar
joeypurcell
Sounds like my rattle. I have secured the rear window, sat people in the back, and still can't find that pesky rattle. It is in the rear, and seams to be closer to the passengers side. I have tried the following.
Seats up/down
Jack out
Rear window open/closed
Rear window tightened with foam and wedged
Foam around where seatbelts bolts to pillar
Bed empty
Bed full
Still no fix for me.
Old Dec 27, 2006 | 12:27 PM
BlackFX4Screw
Well I think I fixed it. Sprayed some silcone on the rubber cab mounts under the truck. I know the rattle did'nt sound like it was coming from there. Have not had the rattle since.
Hope this helps
Old Dec 27, 2006 | 01:40 PM
ford9c's Avatar
ford9c
Thanks for the tip. I will have to see if that helps to get rid of some of my rattles.
Old Dec 27, 2006 | 02:43 PM
CMOS's Avatar
CMOS
Any ideas?
I have that same thing in my 04 SCAB. Sounds like 2 hard peices of plastic banging against each other.
Please let us know if the rattle comes back. It sure sounds like it's coming from inside the cab.
CMOS
Old Dec 30, 2006 | 10:39 AM
BlackFX4Screw
Did the spray on the rubber help you guys out?
Old Jan 2, 2007 | 12:18 AM
is300wrx's Avatar
is300wrx
CMOS
Do you have a roll up tonneau cover by any chance? Because I hvae the same noise and i thought it was the sliding window causing the rubber noise. It ended up being that my tonneau cover was squeaking becase in the colder months, the vinyl shrinks and makes all sorts of noise. Give that a shot
Old Jan 14, 2007 | 07:51 AM
BlackFX4Screw
Anyone have any luck finding this rattle please let us know. Mine has returned.
Old Jan 14, 2007 | 09:35 AM
joeypurcell
Today is the day my entire bak seat is removed. I will let everyone know if there is something back there causing a rattle.
Old Jan 15, 2007 | 05:10 PM
squeeg333's Avatar
squeeg333
I had this same kind of problem. Sounds like wet shoes on a linoleum floor or pieces of rubber rubbing against one another??? There's a tsb out there for the rear window gasket. They just have to re-lube it and it's good to go.
On a side not, one of ya'll said that there is a tsb out there for a rattling sliding rear window? I hope so, mine is driving me nuts.
Old Jan 15, 2007 | 06:07 PM
Mr. PC's Avatar
Mr. PC
You know, I have that sound. It is like two pieces of styrofoam rubbing together. I have noticed that the sound does not occur when it is wet and rainy. I might have to look into that tsb.
PC
Old Jan 15, 2007 | 06:30 PM
squeeg333's Avatar
squeeg333
If I come across the number, I'll let you know. I'll check my records at home, that's got it noted somewhere.
Old Jan 15, 2007 | 07:33 PM
black04lariat's Avatar
black04lariat
when you hear the rattle push up on your center dome light inside. i had a rattle that was driving me crazy and i finally figured it out to be where the dome light is. on the side of the headliner that meets the roof, there were square pieces of foam (hard almost rubber like) on each side of the dome light that were actually hitting the cross bar that goes across the truck. my rattle would even happen like when i would shut my doors. not sure if the cross bars are there in models without a sunroof, but i ripped them out (just glued on) and the rattle is gone. it was actually the headliner moving up and making contact on the square foam pieces with the cross bar. hope it helps
