Heater Identification ?
Old Dec 21, 2006 | 07:56 PM
g84t8f1's Avatar
g84t8f1
Question Heater Identification ?
I have the heater out of my 48.The only mark on it is a rasied 7 with a line thur it.It's on the front right lower corner of the housing.It has a motor with a shaft out each end.1 end has a fan blade the other has a squirrel cage on it.My wife says the mark on the front is a European 7.Any help would be great.
THANKS
ART
Old Dec 21, 2006 | 09:12 PM
fifty2f1's Avatar
fifty2f1
heater id
I believe that 7 is actually a fancy script f denoting ford. I have several of these heaters in my trucks and am pretty sure it's an f.
george
Old Dec 22, 2006 | 05:19 AM
g84t8f1's Avatar
g84t8f1
Thanks.Any idea where to get parts at?I'd like to put a 12 volt motor in it.The 6 volt works good put I'd like to have everything 12 volt.
THANKS
ART
Old Dec 22, 2006 | 07:33 AM
fifty2f1's Avatar
fifty2f1
ford heater
THANKS
ART
Art....I just used voltage reducers on mine, one for each blower speed (mine is a 2 speed) and it works great. I suppose the later 12V ford motors will work but you might have to modify the shaft. There was some info posted recently on these heater motors, like early december.
george
fifty2f1
Old Dec 22, 2006 | 07:44 AM
g84t8f1's Avatar
g84t8f1
I think my motor only has 2 wires 1 ground and 1 hot wire.Might use a reducer.I still have to change out the 2 wires coming out of the motor.They have bare places in them.Is there away to change blower speed on a motor like this?
ART
Old Dec 22, 2006 | 08:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ART
Most factory motors were internally grounded, so a 2-wire would be a 2-speed. But the only way to tell would be to test it. Get a counter guy (or gal) who is sympathetic to let you browse the Siemens catalog, there aren't that many that used the double-ended shaft. Have all your measurements in hand -- shaft length, diameter, motor case length, etc.
Old Dec 24, 2006 | 07:08 AM
g84t8f1's Avatar
g84t8f1
I just checked my motor over and it has a ground wire that hooks to the body of the heater and 1 hot wire.All looks to be factory.I may just replace the old wires and use the motor I have. it works great.But I will see if i can find a 12 volt replacement motor and how much frist.
Thanks for the help.
ART
drwako
Jan 18, 2021 12:33 AM
Walleye Hunter
Apr 3, 2014 05:05 PM
TPM
Jan 15, 2009 12:35 PM
Foxxx
16
Oct 7, 2007 03:53 PM
Crumm
Oct 26, 2003 03:22 PM
