XLT Package
Old Dec 22, 2006 | 09:11 PM
  #31
SuperSnake's Avatar
SuperSnake
Originally Posted by 81-F-150-Explorer
Tool Boxes are more comon in the Bronco I've noticed.
I do not see very many of them when I go to the wrecker, and If I do see one the latch is usually busted. I do see a few though.
I never seen one until coneynew posted his picture of really nice interior parts. Where are they located under the hood?
Old Dec 22, 2006 | 09:14 PM
  #32
81-F-150-Explorer's Avatar
81-F-150-Explorer
It was silicone lubricant. It lubricates plastic and rubber. Doesn't attract dirt as much either.
Prestone is a brand name I have used.
  #33
Coneynew's Avatar
Coneynew
They are on the driver's side front, in parallel wi the the fender. The mounting brackets attach to the inner fender and the other to the engine side of the tool box to hold the winshield wahser / collant overflow container thing.
Old Dec 22, 2006 | 09:18 PM
  #34
SuperSnake's Avatar
SuperSnake
I can only hope to get lucky not many old fords here that still have parts.
Old Dec 22, 2006 | 09:23 PM
  #35
81-F-150-Explorer
Here is my tool box installed.
Notice the overflow bottle attached to it on the left side.
Old Dec 22, 2006 | 09:27 PM
  #36
SuperSnake's Avatar
SuperSnake
81 That's really nice. I also see a bracket between the overflow bottle and the tool box. I am going to look for one after I get some work done on my truck.
Old Dec 22, 2006 | 09:29 PM
  #37
Coneynew's Avatar
Coneynew
I'll post a pic of the brackets separately since I have them off
Old Dec 22, 2006 | 09:35 PM
  #38
SuperSnake's Avatar
SuperSnake
Thanks seems yall have good interior parts and such up there. Down here it gets used up or the sun & heat kills them,seems to get hotter each spring and summer here every year . It's going to be 70 degrees here tomorrow and 67 Sunday here.
Old Dec 22, 2006 | 09:40 PM
  #39
Coneynew's Avatar
Coneynew
I know what you mean. It is to be around 50-55 here in SE PA and raining! The reason I collect these parts is simple, the salvage yard is a "pick-a-part" and they end up crushing the stuff before they have been gone through. Plus, it was a good learning education to learn how these things all go together. Plus, I would always try to help another fellow FTE member find a part, etc
Old Dec 22, 2006 | 10:25 PM
  #40
big hoss 29's Avatar
big hoss 29
https://www.ford-trucks.com/user_gal...oid=95708&.jpg
That has got to be the slickest little toolbox I have ever seen! I did the same thing with an old .30 ammo can on my old 83 F-150, but I never thought that Ford offered an underhood toolbox as an option.
Old Dec 22, 2006 | 10:32 PM
  #41
Coneynew's Avatar
Coneynew
It is actually pretty durable and has a metal lined bottom and it deeper than it looks
Old Dec 22, 2006 | 10:48 PM
  #42
big hoss 29
I do believe that the next time I go out to the "playground", I'm going to have to look for one of those gol-darned thingy-ma-bobs.
I did just find a like-new cargo light off of another 86 F-250 for the rear of 'ol Hoss, so I'm getting ready to cut some metal and install it soon. I'm tired of not being able to see in the bed at night.
Old Dec 22, 2006 | 10:51 PM
  #43
Coneynew's Avatar
Coneynew
Big Hoss - did you also take the wiring harness? Also, may as wel and ad the deluxe dome light w/ map lights too if you grabbed the harness. I added the factory cab light and harness to my 1985 F-350 (will update gallery to show) using the factory harness as well.
Old Dec 22, 2006 | 11:11 PM
  #44
big hoss 29
The light I grabbed only had 2 wires on it. I had thought of getting the deluxe interior light, but I don't really need it. The standard light works really well.
I'm just going to wire the cargo light up with a lighted toggle switch on the instrument panel. I don't want the light to come on when I open the driver side door, just when I turn it on.
Old Dec 23, 2006 | 08:03 AM
  #45
SuperSnake's Avatar
SuperSnake
I need to get a new lens for my inside light. Is the deluxe interior light the one with 2 small lights (map lights) and a big one in the middle?
