Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
torque specs'?
Old Dec 21, 2006 | 01:31 PM
Brent M.'s Avatar
Brent M.
Question torque specs'?
Does anybody out there know the torque specs' for the rear diff. pinion/slip yoke...thanks...Brent M
Old Dec 21, 2006 | 08:30 PM
JFUSION's Avatar
JFUSION
my haynes manual lists three torque #'s for driveshaft parts, they are universal joint cap bolts at 17 ft lbs, front driveshaft to transaxle bolts 27 ft lbs, and center bearing nuts 35 ft lbs. Hopefully these cover the part you need, good luck.
Joey
Old Dec 22, 2006 | 10:15 AM
Brent M.'s Avatar
Brent M.
No,I have those torques thanks...I need the nut torque that holds on the slip yoke(or pinion yoke,whichever name you like to call it)...I looked in my haynes manual as well,but I can't find it there either...I thought maybe someone out there would have a better source of info...thanks anyway.Brent M
Old Dec 22, 2006 | 12:46 PM
butch h's Avatar
butch h
If your talking about the pinion nut(holding the flange/yoke to the pinion shaft at the front of the rear differential),on my '90 Ranger it is 170 ft.lbs.- in other words pretty tight.
Brent M.
Dec 19, 2006 06:06 PM
Brent M.
Jun 14, 2006 10:36 PM
Brent M.
Jun 12, 2006 10:28 PM
brents
Jan 13, 2003 10:12 PM
brents
Apr 24, 2002 11:09 PM
