belt dressing
Old Dec 21, 2006 | 01:04 PM
kdbbmanton's Avatar
kdbbmanton
belt dressing
I have a 2004 f150 4x4 5.4L with 46000 miles on it. @ 32,000 miles I took it to the dealer because of a squeeling from the belt area @ first start up. They said it was the belt, and replaced it. No more problems until today, same thing was going on as before. A belt cannot wear out in 14000 miles? so like an idiot I sprayed some belt dressing on it, now it is 5 times worse than it was!! Please help!!!
Old Dec 21, 2006 | 01:39 PM
schneidz's Avatar
schneidz
oops, personally i have only used belt dressing 1-x in my life many years ago and it was a nasty sticky mess that had goo on the underside of my hood and everywhere else. i would go back to the shop that installed the belt and have them look at it you may have a defective belt or a bad pulley. sorry
Old Dec 21, 2006 | 02:00 PM
kdbbmanton's Avatar
kdbbmanton
What can I use to remove the dressing from everthing?
Old Dec 21, 2006 | 02:42 PM
GlennJ's Avatar
GlennJ
The belt is gone. Get some brake Clean, lacquer thinner or some similar solvent and have at it. It is going to be fun cleaning up the micro groove pulleys. Belt dressing is real, real old school. You do have another problem that still needs to be resolved. Maybe a weak belt tensioner, maybe a component taking too much torque to operate.
Old Dec 21, 2006 | 03:08 PM
ford9c's Avatar
ford9c
I went through the same thing. One tip, remove the air intake tube from the fender wall. Then take off the bracket on the front of the engine it attaches to. This gives you a lot more room to work. Next I used a lot of carb cleaner and worked on all the belt surfaces as well as all the pulleys. You will have to clean out all the pulleys anyway before the belt gets changed or else it will start chirping also. After doing that I got the noise down to an acceptable level and brought it into my dealer. In this case they actually behaved nicely and changed the belt under warranty! When the belt was changed all the chirping noises stopped and haven't come back yet although I'm thinking getting the s belt changed on a yearly basis may be good preventative maintenance.
Old Dec 21, 2006 | 03:19 PM
kdbbmanton's Avatar
kdbbmanton
thanks for the help!!!!!
Old Dec 21, 2006 | 03:50 PM
SteveVFX4's Avatar
SteveVFX4
my belt did that too after only 3000 miles and belt dressing made it worse. The dealer replaced it under warranty, actually I think there is a TSB for it. At 23k miles now, I get a slight chirp every once in a while when it's real cold or damp/dewey out. But it's not loud enough to bug me yet.
Old Dec 21, 2006 | 07:15 PM
YOMAN's Avatar
YOMAN
I replaced it with gatorback belt and no more squeel or whatever it is!! its good brand... you can find it at Auto zone. I highly recommend it!
I learned it from some people on ford forums, they complained about the belt is not really grab, so they replaced it with gatorback and they re happy.
Its very common when your upgraded your engine performance with any tuner program, cat back ettccc.
I think it cost about 25-30 bucks.
YOMAN!
Old Dec 21, 2006 | 11:54 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
look at the alignment of your pulleys as well. the idler pulley may not be maintaining tension properly also.
other than that, a yearly change is a good idea so you're not stranded on the side of the road when/if the belt breaks
Old Dec 22, 2006 | 12:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Look here:
https://www.ford-trucks.com/forums/s...7&postcount=10
Old Dec 22, 2006 | 11:28 AM
LewPoberezny's Avatar
LewPoberezny
Ford does have a TSB forn belt squeel on F-150's
Old Dec 22, 2006 | 03:02 PM
Norvous's Avatar
Norvous
Wd40 Put It On It Will Clean It:-d
Old Dec 22, 2006 | 10:37 PM
spiggy769's Avatar
spiggy769
YOMAN!
Exactly get a gatorback and ya will not have this problem. Same thing was happening to me...changed the belt to a Gator and no more problems,
Old Dec 22, 2006 | 11:03 PM
sharpster68's Avatar
sharpster68
hello
use soap it works good
grider
6.4L Power Stroke Diesel
15
Dec 11, 2019 11:59 AM
Dustin Aubrey
Feb 6, 2010 07:24 PM
74baja
Nov 2, 2009 04:37 PM
seanandnik
Nov 17, 2006 10:55 AM
