"04" 5.4 VALVE TRAIN FAILURE
Old Dec 26, 2006 | 02:06 AM
  #31
yardbird's Avatar
yardbird
04 FX4 Lineman,
Here is a post copied from Consumer Affairs that applies to your truck if you have the 3 valve evgine:
Richard of Melfa VA (11/28/06)
My Ford F-150 5.4L Triton motor has a known problem where the spark plugs break off during routine changing requiring the cylinder heads to be pulled. My truck ran perfectly before I took it in for service. Now I am without a vehicle for an unknown amount of time.
The estimate is $1600 so far. All 8 of my spark plugs are stuck in the motor. The Ford customer service line stated there is no known Ford program to help with this problem. The online forums are full of similar stories. This is not right, it is a Ford problem. The customer service stated it is a dealer problem because they broke the plugs.
Spark Plug Issues, mostly 2 valve engines:
http://www.consumeraffairs.com/autom...ord_spark.html
Old Dec 26, 2006 | 09:11 AM
  #32
marlinlander's Avatar
marlinlander
"04" F-150 ENGINE FIXED
WELL I GOT MY TRUCK BACK NEW CAM/LIFTERS RUNS GREAT.I APPRIECIATE
INPUT FROM EVERYONE
Old Dec 26, 2006 | 11:28 AM
  #33
04 FX4 Lineman's Avatar
04 FX4 Lineman
Originally Posted by yardbird
04 FX4 Lineman,
http://www.consumeraffairs.com/automotive/ford_spark.html
Yardbird: Thanx for the info and the link as this is my engine 5.4 3V it is nice to hear from someone here who is brutaly honest most here just make excuses for ford I also amnot one to do that, I have the extended warranty so will have a dealer do my plugs and if they do screw it up hopefully it will be their issue. I would like to stay with ford but if this problem isn't corrected my next truck may be something different?? Thanx again.
Old Dec 27, 2006 | 04:50 AM
  #34
captchas's Avatar
captchas
Guest
4 threads or 6 threads. use a ruler the real lengh is 3/8's thats what i ment. and what had been used by almost every manufactor
as to seating i've seen lawn mower motors with a 3/8inch washer plug pop out. air cooled bettles as far back as the early ones of the 1950's pop out. they had a 3/8ths washer seal plug. i've see nissans, toyota's, audi/vw's with long thread lengh plugs pop out. i even had my f.i'd merc. out board pop them every one took out the threads. talk about costs on the merc, ob. ouch
yes i agree they should give up on the 3/8ths, tappered seat but then every one should also even gm's marine line.
incompateable metals are our problem with few companys taking advise from the marine ind. and useing stainless steel which is more compatable all around. they are useing s.s plugs why can't every one else?
Old Dec 27, 2006 | 04:53 AM
  #35
captchas's Avatar
captchas
Guest
small warning the others are no better infact worse. i had 2 dodges both with 4.7 v8's both had head gasket problems and 1 blew a plug at 75mph on a state run road. tow bill =ouch my six hurts still.
Old Dec 27, 2006 | 07:08 AM
  #36
7700Rob's Avatar
7700Rob
INPUT FROM EVERYONE
Well, I'm glad you're rolling now, best wishes with your new truck! too bad this thread turned into nothing related to your post.
mdec950
May 6, 2012 01:13 PM
ToMang07
Jun 19, 2011 10:58 PM
Greywolf
31
Mar 8, 2009 08:15 PM
bartamos
1997 - 2003 F150
17
Dec 13, 2006 03:16 PM
