Bad proportioning valve?
This forum has helped me alot with a similar problem I am having.. I am working on an 87ish ford areostar van. I've got NO pressure to the rear brakes. the front one work fine, great in fact... but not a single drip to the rear.... I've taken apart the proportioning valve and cleaned it out(like new IMO) and put it back together the same way..... when I install it I still have great pressure to the front but not a drip again the to the rear.... whats goin on?
I've take off the rear line(disconected it from the proportioning valve on the bottom) and when my asst. pumps the breaks I'm getting only drips from the bottom of the valve.... if I do the same to the front line(on the valve) it squits like crazy..... why am I not getting pressure in the valve to counter that spring in there to get fluid to the rears?
Thanks in advance!
https://www.ford-trucks.com/forums/2...t-in-here.html
By the way, welcome to the Aerostar forum!
or
proportioning valve shuttle piston is propbably stuck to front brake side from corrosion or damage....or feed hole to rear brakes is plugged by debris....
replace combination/proportioning valve is best at this point
you had mentioned a "feed hole to the rear". I looked all around this cone inside(that has a tension/return spring with it) and I saw the hole in the front side of the cone, but no exit to it. I cleaned it out and checked again, but I don't see a hole for the fluid to go from inside the cone(shuttle piston?) to the back of it(sealed with a gasket)... am I missing something?
To me it appears that there is absoutally NO path for the fluid to get from the feeder hose(on top) to the line hose(in the rear). it would make sence now that there SHOULD be a pin hole or something.... if that was the case then I missed the hole(and didn't clean good enough).
is that all I'm missing is that hole? or is there something else goin on?
thanks again!
I'm guessing that everything was OK until you start bleeding the rear brakes.
The proportioning valve has a safety shuttle valve that's normally open to allow fluid to reach the rear brake line. When you have a catastrophic failure (leak) in the rear brakes, the valve is closed off to prevent fluid from reaching the rear line, just so you still have pressure on the front brakes and you don't lose all fluid.
When people bleed the rear brakes, they usually have soneone else pump the pedal several times and then open the rear brake bleed valve. Alas, this simulates exactly the condition the shuttle valve is designed to prevent, and it promptly closed up. that's why you don't see any more flow to the rear.
That's why this valve on the Aerostar is not exactly called a "proportioning valve," but a "combination valve" since it combines both functions in one body.
About the only thing you can do is to open up the proportioning valve and try to clean up everything, if it's not too badly corroded.
So now the question becomes; When I put it all back together, do I put the piston ALL the way into the valve?(That seems to stop all fluid) or do I place it in there so there is a gap in the back of the valve to allow fluid to pass?
Then, how do I bleed this system? if I cant pump it? just open all 4 bleeder screws and let it sit for 5-10 mins?
Thanks again everyone!
center the shuttle piston in comb/prop. valve....fill fluid reservior on mc....i flush and bleed my brakes all by myself using a rubber hose over bleeder screw **** into partially filled can of brake fluid to prevent sucking back in air.....i pump up the brakes... crack bleeder until fluid flows...pump brakes gently several times only 1/2 way down....close bleeder and move to next wheel
secret is gentle slow brake pumping only half way down....knowledgable assistant helps....that leaves out most wives
RR, RF, LR then LF per Ford RABSII/ABS manual
probably RR, LR, RF, LF for non ABS
when I disassemble the combo valve. I DONT push the shuttle piston all the way back.. I just place it in there and then put on the spring and cap right?
this makes alot of sence as when I push it to the back I can't get fluid to the rears...
Thanks so much 96_4wdr!
and the van is NONabs. so I agree that its RR,LR,RF,LF. as to do the longest to shortest lines..
Thanks again to everyone. I'm going to give it the old college try in the AM tomarrow. I'll let you know how it go's.
-Thanks all
-GrageNut
If you have a VOM or DMM, you can check for the correct position of that shuttle valve. There is a screw-in sensor on the front of the MC that has a contact point that is designed to touch the shuttle valve if it is out of place. If this happens, it completes a circuit to ground. So you connect one probe of the DMM to ground, the other to the terminal of the sensor, and put the meter on continuity check or Ohm reading. If the valve is out of place enough to touch the sensor, you should see it on the meter. Normally, if the valve is positioned correctly, it will not touch the sensor.
