1999 with dana 50 front diff?? No posi options?
Hi,
I have a '99 superduty F-250, extended cab, powerstroke with a failed front differential. I need to get it rebuilt and want to have a detroit true-trac or some other limited slip installed while the the whole thing is being taken appart.
Now for the surprises:
I am told that the front end is a Dana 50, not a Dana 60.
Further, there are no aftermarket limited slip options for a Dana 50.
Does this sound right?
Do I have to hunt down a used Dana 60 just to get an aftermarket limited slip in my front differential?
Thanks,
Jon
Thanks,
Jon
Yes, it can be a DANA 50. This from the Randy's ring and pinion site:
<i>Dana Spicer D50 Years Used on F250: (1980 - 2004)
Ford front end, found in both straight axle and independent front suspensions. Identifiable by outside clips on axle u/joints. </i>
They also list multiple locker and limited slip options for the D50 differential.
http://www.randysringandpinion.com/Default.aspx
fordmanva
03-13-2012 09:23 PM
78 Ranger
09-05-2006 09:24 PM
