460 Alternator Install
Old Dec 19, 2006 | 01:45 PM
Voh's Avatar
Voh
Can some one please take a picture of how the alternator installs on a 1973 ford 460? I removed it some time ago and cannot figure it out for the life of me.
Old Dec 19, 2006 | 03:44 PM
bassdude's Avatar
bassdude
if you're facing the front of the motor it hangs down on the left side about even with the balancer. i'll see if i can find a good close up pic
Old Dec 19, 2006 | 04:20 PM
Mil1ion's Avatar
Mil1ion
There were two
Upper mount or lower mount ?
Old Dec 19, 2006 | 05:46 PM
banjopicker66's Avatar
banjopicker66
Here is the lower one on a '78 460 in a F-250 ( and it is NOT a Lincoln transplant):
Old Dec 19, 2006 | 09:24 PM
Voh's Avatar
Voh
that last picture is just waht i was looking for. Thanks for all the responses. That leads me to my next question, how do you run the water pump without the power steering pump? the crank and the w.p. line up, but there isn't anything to take up the extra belt slack. could one maybe replace the alternator pulley with one that stands of a bit more and run a single belt around the alt-crank-water pump?
Old Dec 19, 2006 | 09:35 PM
Mil1ion's Avatar
Mil1ion
Idler pulley
Old Dec 19, 2006 | 10:04 PM
scottie2hottie's Avatar
scottie2hottie
I have that setup and the alt and PS are on separate belts....???? Both go around water pump and crank, but not around BOTH the PS and Alt.
Old Dec 20, 2006 | 07:29 AM
Voh's Avatar
Voh
Mil1ionI like the thought of an idler-pully, just not sure where to begin as far as tracking one down, new is fine. Any idea of a part number that would work nicely without a termendous amount of fabricating?
Scottie2Hottie
Do you have any pictures? My alternator is in the low mount position, which uses the back (1of3) crank pulley by its self. From what I can tell the next crank groove lines up with the water pump, but then there isn't any adjustment. the front groove on the w.p. and the front groove on the crank do not match - they are off ever so slightly.
Old Dec 20, 2006 | 08:17 AM
wizzard351's Avatar
wizzard351
i used a short belt that go's straight up to the wpump with no idler. ill go see if theres still a number on it and let ya know later today.the only bad part about it is ya have to take of the wpump pully and put the belt around the crank and the pump pully them pull up on the pully pretty hard to get it over the pump shaft.i know some ones goin to say well how ya tighten it then its so tight when ya get it on there ya dont have to tighten it and in a couple years when and if ya do need to tighten it just go get another 10dollor belt
Old Dec 20, 2006 | 12:36 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i cant remember how its looks of hand, but if the alt pulley needs to be further out to match up, then you can go buy a double groove pulley to put on it and leave the inside belt like it is and attach the outside belt to the wpump....i hope that made sense....
Old Dec 20, 2006 | 01:03 PM
Voh's Avatar
Voh
That was another thought that I had. Any idea of years to look for/ask about?
Old Dec 21, 2006 | 05:11 PM
Mil1ion's Avatar
Mil1ion
Just get the alternator bracketry for the upper mount.
The alternator stays cleaner and it is always easier to adjust..
It then lines up with the other crank pulley and you have the adjustment at hand.
Old Mar 17, 2010 | 02:27 PM
bennh62's Avatar
bennh62
Documented alternator install with photos on a 1976 460
I have details of an alternator install on a 1976 F350 460 that should be the same setup as yours. Lots of photos too: Replace Alternator on 1976 Ford F-350 Super Camper Special benhavilland
Old Mar 17, 2010 | 06:43 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Holy Post Resurection Batman!
Josh
Old Mar 17, 2010 | 07:25 PM
bennh62's Avatar
bennh62
Josh
I thought the thread was more recent, don't know why. Anyway, maybe the photos can help somebody.
Just looked at the dates and how is it that somebody has a join date after their post date?
